What's the story on conversion from string to decimal?
    I still get this alot in the log when controlling my 3808 with the Denon plugin:
    1.06.2010 18:30:03 Event Running script statement immediately: &hs.plugin("DenonAVR").PwrOnAVR()
    01.06.2010 18:30:03 DenonAVR Error Exception error in Parse_TFAN_Status(): Conversion from string "087.50" to type 'Decimal' is not valid.
    01.06.2010 18:30:04 Event Waiting 0 minute(s) 12 second(s) 0 millisecond(s)
    01.06.2010 18:30:16 Event Running script statement immediately: &hs.plugin("DenonAVR").SetInputAVR("SAT")
    01.06.2010 18:30:16 DenonAVR Error Exception error in Parse_TFAN_Status(): Conversion from string "087.50" to type 'Decimal' is not valid.
    What can we do about this?
    The problem is that here we use a comma ( "," ) as a decimal separator so the casting from the string "87.5" doesn't give a value of 87,5...
    I will try and look at it this weekend...most of the Radio stuff is still under R&D as the documentation states...but the routines that I've already coded, I will see if I can modify to except a comma as well.
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
      That would have been great, thanks!
      I don't like error messages in the log, especially since I don't think there's anything wrong.
      ... and I don't even use the radio.
        *BUMP* It's been two months...
          I have not had time to look at it yet...maybe this weekend.
          -Larry
          Plugins:
          Hardware:
            I wanted to let you know, that I've started work on a new version of the plug-in...the changes might be be pretty significant, as it looks more like a total re-write of the basic engine. Some of the choices I made before are limiting my capabilities now, so I started a new foundation to build on, hopefully this will make things a little easier.
            -Larry
            Plugins:
            Hardware:
              Wow, hope it is as promising as it sounds.
                Almost finished with new version...will need a few more days to re-work some scripting commands, and test new features...thanks for being patient.
                -Larry
                Plugins:
                Hardware:
                  Woho!
                  If you haven't seen it already, here's some inspiration:
                  http://forums.homeseer.com/showthread.php?t=144172
                    I did add quite a few devices to the a status page, but not anything that elaborate as far as controls...wow...it does inspire me to research that capability though.
                    -Larry
                    Plugins:
                    Hardware:
                      See Sticky...New version sent to updater.
                      -Larry
                      Plugins:
                      Hardware:
                        Great! Looking forward to test it!
                          OK, I've updated. But I don't see any changes. Excpet that the page /denonavr_control does not load any more, and now I even get the this error when I'm trying to open the page: "Error Calling GenPage for plugin, link: /denonavr_control Error: Conversion from string "0087.50" to type 'Decimal' is not valid".
                          Version number is 2.2.1.17.
                            OK, this plugin seriously needs help!
                            11.10.2010 19:51:18 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "39.5" to type 'Double' is not valid.
                            11.10.2010 19:51:19 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "38.5" to type 'Double' is not valid.
                            11.10.2010 19:51:20 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "37.5" to type 'Double' is not valid.
                            11.10.2010 19:51:21 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "36.5" to type 'Double' is not valid.
                            11.10.2010 19:51:22 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "35.5" to type 'Double' is not valid.
                            11.10.2010 19:51:23 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "34.5" to type 'Double' is not valid.
                            11.10.2010 19:51:25 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "33.5" to type 'Double' is not valid.
                            11.10.2010 19:51:26 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "32.5" to type 'Double' is not valid.
                            11.10.2010 19:51:27 DenonAVR Error Exception error in Parse_MV_Status(): Conversion from string "31.5" to type 'Double' is not valid.
                            Seems to happen when I adjust the volume.(?)
                            Period is still not a decimal separator here in Europe!
                            Here's my new proposal:
                                Private Sub Test()
                                    Dim str As String = "70.5"
                                    Debug.WriteLine(str)
                                    str = str.Replace(".", System.Globalization.NumberFormatInfo.CurrentInfo.NumberDecimalSeparator)
                                    Dim d As Double = str.ToString
                                End Sub
                              I will see what I can do.
                              -Larry
                              Plugins:
                              Hardware:
