After trialing this plugin for a while using a network connection to my Denon AVR 3808, I decided to buy it and use a serial connection. In terms of controlling the receiver, everything seems to work fine. I can turn it on and off, switch sources, raise and lower volume.
The problem is with the DenonAVR devices that the plugin creates. These do not show any status properly. Everything is shown as "disconnected" or "no status." When I try to recreate the devices from the plugin page, I get a bunch of these warning messages in my Homeseer log:
I assume this is why my statuses are not working. I am using HomeSeer 2.5.0.1 on Windows XP, and have version 2.2.1.9 of the DenonAVR plugin. Any idea how I can fix this problem? Thanks for any help!
Warning 'status' property on device DenonAVR DenonAVR Status was accessed - this property has been deprecated and should not be used. Warning 'status' property on device DenonAVR Power was accessed - this property has been deprecated and should not be used. Warning 'status' property on device DenonAVR Main Zone Status was accessed - this property has been deprecated and should not be used. Warning 'status' property on device DenonAVR Main Mute was accessed - this property has been deprecated and should not be used. ...
