Try this test version.
    Attached here is a test version (version 2.2.1.12) to see if your issues were correctly addressed...please unzip and place into HomeSeer directory...if it looks good to everyone, then I will send it to the updater.
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
    Very cool!
    Will report back...
    Transitioning to HS3Pro .298 - WinXPEmbedded
    Hometroller S3 Pro - WinXPEmbedded - HSP 2.5.0.81 - BLStat - HSPhone - HSTouch Srvr 1.0.0.73 - Touchpad - BLLan - BLOccupied - DSC Plug 2.0.0.14 - BLStat .38
      Thanks for this update! I am trying it in RS-232 mode, and it does seem to connect. I noticed you now allow the SetVolAVR script function to accept a numeric argument (thanks for that!!), however I think there must still be an issue.
      If I call VolStatusAVR I get back a number like "-45". However, if I try to pass a negative number into SetVolAVR I get an error message in the HomeSeer log saying "Master volume must be in the 10 - 90 dB range". However, if I pass in a positive number (such as "30"), nothing seems to happen. The volume level does not change, and the value returned by VolStatusAVR continues to be "-45" before and after the call to SetVolAVR.
        I'll check into the setvol script function...but will have to wait until after Christmas or family will have me tarred & feathered.
        -Larry
        Plugins:
        Hardware:
          I hear you, me too if I keep messing with it! Merry Christmas and thanks for your hard work!
            Better !!!
            But...
            1) All the time i have :
            "No Connection" for the device DenonAVR
            ( Status #1 Plug-In Status Never Set )
            2) the SetVolAVR problem here is my log :
            25/12/2010 18:08:23 DenonAVR Error Master volume must be in the 10 - 90 dB range.
            25/12/2010 18:08:23 DenonAVR Debug Entering...DenonAVR user function SetVolAVR().
            25/12/2010 18:08:23 System Control Panel Immediate Script: &hs.plugin("DenonAVR").SetVolAVR("-30")
            25/12/2010 18:08:09 DenonAVR Debug SendDenonComm()...is sending command: MV30, using ComPort: COM1
            25/12/2010 18:08:09 DenonAVR Debug Entering SendDenonComm()....
            25/12/2010 18:08:09 DenonAVR Debug Entering...DenonAVR user function SetVolAVR().
            25/12/2010 18:08:09 System Control Panel Immediate Script: &hs.plugin("DenonAVR").SetVolAVR("30")
            25/12/2010 18:08:03 DenonAVR Debug SendDenonComm()...is sending command: MV30, using ComPort: COM1
            25/12/2010 18:08:03 DenonAVR Debug Entering SendDenonComm()....
            25/12/2010 18:08:03 DenonAVR Debug Entering...DenonAVR user function SetVolAVR().
            25/12/2010 18:08:03 System Control Panel Immediate Script: &hs.plugin("DenonAVR").SetVolAVR("30")
            3) The refresh of the status of the device don't work.
            I can't find why or when the refresh is executed
            4) The status text
            The status could be OFF (must be Off)
            The status could be ON (must be On)
            Attached I send you a screen capture
            => All the over function seems to work
            (script or Immediate Script Command)
            => All the button work
            Thank's for your work and Merry Chrismas
              Bummer, tried to help test this but I dont have a license. The demo wont let me try it either. Says unlicensed when I try to apply the update when it said I had x days left on my trial.
              I have a 3810ci that I can test with...
              Thoughts?
                Another thing
                I have strange message in my log file (in red) i send you an example.
                25/12/2010 18:54:46 DenonAVR Debug Parse_SS_Status()...SOD: DEL
                25/12/2010 18:54:46 DenonAVR Debug ParseResponseLst()........
                25/12/2010 18:54:46 DenonAVR Debug ParseSerialCommandResponse()........
                25/12/2010 18:54:46 DenonAVR Debug Event---RS232Port_DataReceived()...
                25/12/2010 18:54:46 DenonAVR Debug Parse_SS_Status()...FUN: TUNER
                25/12/2010 18:54:46 DenonAVR Debug Parse_SS_Status()...FUN: V.AUX
                25/12/2010 18:54:46 DenonAVR Debug Parse_SS_Status()...FUN: DVR
                25/12/2010 18:54:46 DenonAVR Debug Parse_SS_Status()...FUN: VCR/iPod
                25/12/2010 18:54:46 DenonAVR Debug Parse_SS_Status()...FUN: SqueezeB
                25/12/2010 18:54:46 DenonAVR Debug Entering SendDenonComm()....
                25/12/2010 18:54:46 DenonAVR Debug SendDenonComm()...is sending command: ZM?, using ComPort: COM1
                25/12/2010 18:54:46 DenonAVR Debug SendDenonComm()...is sending command: TMAN?, using ComPort: COM1
                25/12/2010 18:54:46 DenonAVR Debug SendDenonComm()...is sending command: TPAN?, using ComPort: COM1
                25/12/2010 18:54:46 DenonAVR Debug Parse_SS_Status()...FUN: PC
                25/12/2010 18:54:46 DenonAVR Debug SendDenonComm()...is sending command: TFAN?, using ComPort: COM1
                25/12/2010 18:54:46 DenonAVR Debug SendDenonComm()...is sending command: SSXPN ?, using ComPort: COM1
                Regards
                  New version problems
                  I tried the plug-in that was posted on Dec 24th. This version is better, but still has a lot of problems - for instance the denon will go into standby /on etc using the devices page, but when i try to use the DenonAVR page the power on /off functions do not work and the volume (min, mid, high etc) only work rarely. The input controls for main only work sporadically as well.
                  In this version, I can see more status messages being returned, and can see status being exchanged/logged when i use the IR controls with the denon, but the status fields in Homeseer are not accurate...
                  As a check, i brought up the Girder controls for the Denon, and they still work to control the unit (Girder does not try to report status, it only seems to control the unit...)
                    OK here is another test version....
                    Version 2.2.1.13
                    Added new script functions to set dB volume levels directly using dB values like 38 or 40.5 or -30
                    Updated help page DenonAVR-Doc.htm (belongs in "C:\HS directory\html\DenonAVR\"
                    Numerous other fixes..I hope...this version is still development, so there may still be some problems.
                    Please let me know how things are progressing.
                    -Larry
                    Plugins:
                    Hardware:
                      Does this plugin support the 3810ci? Also is this for 232 or Ethernet connectivity?
                      Thanks!
