DenonAVR Error - Exception error InitIO():...
    Hi,
    Whats up w/ the line "DenonAVR Error - Exception error InitIO(): Public member 'WriteLogEx' on type 'hsapplication' not found."? Nothing works. Please help.
    I have no problem controling my A/V via COM1 using other software.
    Denon AVR 2809
    Best regards, L
    EVENT LOG
    2011-11-23 21:32:10  - DenonAVR Info - Application path: C:\Program Files (x86)\HomeSeer HSPRO
    2011-11-23 21:32:10  - DenonAVR Info - RegisterCallback Completed...
    2011-11-23 21:32:10  - Info - Initializing Plug-in: DenonAVR on COM port 1
    2011-11-23 21:32:10  - DenonAVR Debug - CreateLogsDir()- Log directory already exists.
    2011-11-23 21:32:10  - DenonAVR Debug - About to read config file entries
    2011-11-23 21:32:10  - DenonAVR Debug - LoadConfigSettings()........
    2011-11-23 21:32:10  - DenonAVR Debug - ***************************************
    2011-11-23 21:32:10  - DenonAVR Debug - DenonAVR Debug Enabled.
    2011-11-23 21:32:10  - DenonAVR Debug - DenonAVR Debug Logging to AppDirPath\Logs\DenonAVR.log.
    2011-11-23 21:32:10  - DenonAVR Debug - DenonAVR HS-Version: 2.3.0.19
    2011-11-23 21:32:10  - DenonAVR Debug - DenonAVR Plug-In Version: 2.2.1.13
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [4
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [1
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [3
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [17
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [5
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [6
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [7
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [8
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [16
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [10
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [11
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [12
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [13
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [14
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [15
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [9
    2011-11-23 21:32:10  - DenonAVR Debug - Found a plug-in device at [2
    2011-11-23 21:32:10  - DenonAVR Debug - Entering InitDenon()....
    2011-11-23 21:32:10  - DenonAVR Info - ComPort is Initializing....
    2011-11-23 21:32:10  - DenonAVR Info - COM1: Opened Successfully.
    2011-11-23 21:32:10  - DenonAVR Debug - AddHandlers()........
    2011-11-23 21:32:10  - DenonAVR Error - Exception error InitIO(): Public member 'WriteLogEx' on type 'hsapplication' not found.
    2011-11-23 21:32:10  - DenonAVR Debug - DenonAVR is shutting down IO.........
    2011-11-23 21:32:10  - DenonAVR Debug - Entering CloseComPort()....
    2011-11-23 21:32:10  - DenonAVR Info - COM1 Closed.
    2011-11-23 21:32:10  - Info - Finished initializing plug-in DenonAVR
    2011-11-23 21:49:56  - DenonAVR Debug - Entering SendDenonComm()....
    2011-11-23 21:49:56  - DenonAVR Error - SendDenonComm()... ComPort is not open or String length is Zero.
    2011-11-23 21:49:57  - DenonAVR Error - Exception error in GenPage().
    2011-11-23 21:50:02  - DenonAVR Debug - Entering SendDenonComm()....
    2011-11-23 21:50:02  - DenonAVR Error - SendDenonComm()... ComPort is not open or String length is Zero.
    2011-11-23 21:50:02  - DenonAVR Debug - PagePut()...Input Selected: DVD
    2011-11-23 21:50:02  - DenonAVR Error - Exception error in GenPage().
    2011-11-23 21:50:49  - DenonAVR Debug - Entering SendDenonComm()....
    2011-11-23 21:50:49  - DenonAVR Error - SendDenonComm()... ComPort is not open or String length is Zero.
    2011-11-23 21:50:49  - DenonAVR Debug - PagePut()...Input Selected: TUNER
    2011-11-23 21:50:49  - DenonAVR Error - Exception error in GenPage().
    2011-11-23 21:51:54  - DenonAVR Debug - Entering ButtonPressEx()....
    2011-11-23 21:51:54  - DenonAVR Debug - In ButtonPressEx for DenonAVR Main Mute, button pressed is  Mute Toggle
    2011-11-23 21:51:58  - DenonAVR Debug - Entering ButtonPressEx()....
    2011-11-23 21:51:58  - DenonAVR Debug - In ButtonPressEx for DenonAVR Main Mute, button pressed is  Mute Toggle
    2011-11-23 21:52:45  - DenonAVR Debug - Entering ButtonPressEx()....
    2011-11-23 21:52:45  - DenonAVR Debug - In ButtonPressEx for DenonAVR Power, button pressed is Standby
    2011-11-23 21:52:45  - DenonAVR Debug - ButtonPressEx Off/Standby for Power : Off
    2011-11-23 21:52:45  - DenonAVR Debug - Entering SendDenonComm()....
    2011-11-23 21:52:45  - DenonAVR Error - SendDenonComm()... ComPort is not open or String length is Zero.
    DenonAVR.log
    2011-11-23 21:32:10 ~***************************************
    2011-11-23 21:32:10 ~DenonAVR Debug Enabled.
    2011-11-23 21:32:10 ~DenonAVR Debug Logging to AppDirPath\Logs\DenonAVR.log.
    2011-11-23 21:32:10 ~DenonAVR HS-Version: 2.3.0.19
    2011-11-23 21:32:10 ~DenonAVR Plug-In Version: 2.2.1.13
    2011-11-23 21:32:10 ~Found a plug-in device at [4
    2011-11-23 21:32:10 ~Found a plug-in device at [1
    2011-11-23 21:32:10 ~Found a plug-in device at [3
    2011-11-23 21:32:10 ~Found a plug-in device at [17
    2011-11-23 21:32:10 ~Found a plug-in device at [5
    2011-11-23 21:32:10 ~Found a plug-in device at [6
    2011-11-23 21:32:10 ~Found a plug-in device at [7
    2011-11-23 21:32:10 ~Found a plug-in device at [8
    2011-11-23 21:32:10 ~Found a plug-in device at [16
    2011-11-23 21:32:10 ~Found a plug-in device at [10
    2011-11-23 21:32:10 ~Found a plug-in device at [11
    2011-11-23 21:32:10 ~Found a plug-in device at [12
    2011-11-23 21:32:10 ~Found a plug-in device at [13
    2011-11-23 21:32:10 ~Found a plug-in device at [14
    2011-11-23 21:32:10 ~Found a plug-in device at [15
    2011-11-23 21:32:10 ~Found a plug-in device at [9
    2011-11-23 21:32:10 ~Found a plug-in device at [2
    2011-11-23 21:32:10 ~Entering InitDenon()....
    2011-11-23 21:32:10 ~AddHandlers()........
    2011-11-23 21:32:10 ~DenonAVR is shutting down IO.........
    2011-11-23 21:32:10 ~Entering CloseComPort()....
    2011-11-23 21:49:56 ~Entering SendDenonComm()....
    2011-11-23 21:50:02 ~Entering SendDenonComm()....
    2011-11-23 21:50:02 ~PagePut()...Input Selected: DVD
    2011-11-23 21:50:49 ~Entering SendDenonComm()....
    2011-11-23 21:50:49 ~PagePut()...Input Selected: TUNER
    2011-11-23 21:51:54 ~Entering ButtonPressEx()....
    2011-11-23 21:51:54 ~In ButtonPressEx for DenonAVR Main Mute, button pressed is  Mute Toggle
    2011-11-23 21:51:58 ~Entering ButtonPressEx()....
    2011-11-23 21:51:58 ~In ButtonPressEx for DenonAVR Main Mute, button pressed is  Mute Toggle
    2011-11-23 21:52:45 ~Entering ButtonPressEx()....
    2011-11-23 21:52:45 ~In ButtonPressEx for DenonAVR Power, button pressed is Standby
    2011-11-23 21:52:45 ~ButtonPressEx Off/Standby for Power : Off
    2011-11-23 21:52:45 ~Entering SendDenonComm()....
    Let me try to recreate your error and see what's going on.
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
      Please do!
      I would really like to use this plug-in.
      I paid for the plug-in before I tried it didn't know I could try it for free. Not very happy.
      Best regards, L
