AVR-3312
    AVR-3312
    Hello,
    Is 3312 supported in the HS3 version? I am currently using HS2 and tried this plugin. It seems to work, but the inputs are not the same. I need to be able to switch to BD, SAT/CBL, TV, for instance. These are not available in the HS2 plugin.
    I noticed that in the ini file there is a field for Denon model name. Does it affect anything?
    Originally posted by anhakkar View Post
    Hello,
    The HS3 plugin should support the same devices as HS2 version. The model number in the ini file was just to help me in troubleshooting logs. I will take a look at the manufactures API document to see if 3312 is supported with additional functions, or just the Denon general API functions.
    -Larry
    A member of "The HA Pioneer Group", MyWebSite
    Plugins:
    VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
    Hardware:
    Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
