Hi guys,
I'm looking to do a A/V solution using HS3. The GC-100-18R seems to be exactly what I want. A couple of questions though:
* Why is the plug-in still Beta? Is it flakey??
* I will need to train it on IR codes. Is there a library of these codes? Will I need to buy a GC-IRL IR LEARNER as well?
A little more on my application. I indeed to turn 4 of the ports into inputs and 2 as IR outputs. I will use two of the relays. Would like to control everything with HS3 over ethernet.
Thanks for any inputs!!
Tahl
Tahl
