Hi,
I have Homeseer V2.x with the GC-100 plug in and a GC-100-12 connected OK on IP address 192.168.2.100, access OK from Homeseer and a network browser, everything else pretty much default. I am trying to set up the infrared devices on that IP address, module 4, connector 1, which is correct according to the GC data. I keep getting the following error message below each line on the IR zone setup page:
Zone 1 Living Room IP192.168.2.100 Module 4 Connector 1
The above referenced module and connector does not appear to be valid.
Any ideas what I am doing wrong?
I must say that the data available to setup HS with the GC-100 is very sparse. One or two worked-through real-life examples would be really, really welcome!!
