GC Plugin Problem
    GC Plugin Problem
    Hello,
    I have been using the GC plugin for a while without too many problems (although its one of my least favorite HS solutions!) but this weekend I want to integrate my garage doors. I went to check my GC setup and it appears that the plugin is no longer working properly - please see the attached screen.
    I used to get three hyperlinks to configure the GC on this page, and there used to be a config button. Also if I try to enable the IR option, nothing happens, no error in the log, and it stays disabled.
    I have tried reinstalling the plugin from the updater.
    Any suggestions
    Jon
    Hello Jon,
    One thing you might want to try, is to do a manual reset of the GC-100 unit itself. It's a little tricky, since you have to short two of the serial pins to do it, but the instructions can be found on the GC website. I've found that sometimes after a bad electrical storm or power outage, my GC-100 doesn't recover a 100% of the time and that once I perform the reset, the plug-in can talk to the unit once again.
    Just a thought!
    -Todd
    ____________________________________________________________ ________________
    HS2Pro: 2.5.0.81 :: HS3Pro (beta) || Plugins:| SmartHome PowerLinc USB, Global Cache, BLBackup, DooCPU Monitor, DooMotion, BLOutlook, BLIcon, BLOutgoingCalls, OutgoingCalls, ROC-Rnd, HSTouch iPhone, UPS Monitor, DooMenuBar, BLSpeech, HSTouch Server, WAF AB8SS, mcsTemperature, VWS, BLChart, RFXCOM, ISY Insteon, iAutomate RFID, iTunes, NetCAM, DSC Security, Nest
      Are there any errors in your HomeSeer log when you restart HomeSeer?
        No, no errors at all.
        Jon
          Originally posted by tmcgowan View Post
          Hello Jon,
          Just a thought!
          Thank you - I will try this tonight and get back
          Jon
