I recently started using the gc-100 plugin with my gc-100 but am constantly met with the following error:
I have verified that nothing else is attempting to connect to the gc-100 at the time (but when I shut down HS and use another program to communicate with the gc-100 they do so without issue so the error is HS specific).
I put in a support ticket a couple weeks ago to no avail.
If I continue to try to send ir it will eventually go but I'll typically see this error a few times first.
Any help would be greatly appreciated as the plug-in is basically useless if it doesn't send ir.
Cheers!
<table border="0" cellpadding="0" cellspacing="2" width="100%"><tbody><tr><td colspan="1" class="LOGDateTime0" align="left" nowrap="nowrap">[COLOR=#000000]9/14/2010 12:53:52 PM [/COLOR]</td><td colspan="3" class="LOGType0" align="left"> [COLOR=#000000]Global Cache GC100 [/COLOR]</td><td colspan="8" class="LOGEntry0" align="left">[COLOR=#000000]Connect Error: Once the socket has been disconnected, you can only reconnect again asynchronously, and only to a different EndPoint. BeginConnect must be called on a thread that won't exit until the operation has been completed.[/COLOR]</td></tr></tbody></table>
Cheers!
