I have a GC-100 that over time stops working. When I restart HS, the script works fine for a while. Then at some point, there is a problem. The script returns successful results, but the action intended does not occur and the following error is in the log.
The error is:
Global Cache Serial Error: Once the socket has been disconnected, you can only reconnect again asynchronously, and only to a different EndPoint. BeginConnect must be called on a thread that won't exit until the operation has been completed.
The script is:
Sub SendData(strData)
hs.WriteLog "Debug", "Starting SendData Script"
DIM GC
DIM SerIdx
DIM SerResult
DIM cmd
Set GC = Nothing
Set GC = hs.Plugin("Global Cache GC100")
if GC is Nothing then Exit Sub
hs.WriteLog "Debug", "Got the plugin"
SerIdx = GC.GetSerialIndex("192.168.1.71", 1)
hs.WriteLog "Debug", "Serial Index "+ Cstr(SerIdx)
if SerIdx = -1 then Exit Sub
hs.WriteLog "Info", "Got the serial Index"
cmd = strData + vbCr
SerResult = GC.SendSerialData(SerIdx, cmd)
hs.WriteLog "Debug", "Think I've changed it (" + Cstr(SerResult) + ")"
End Sub
The error is:
The script is:
DIM GC
DIM SerIdx
DIM SerResult
DIM cmd
Set GC = Nothing
End Sub
