iTach Firewall Issue (Zonealarm)
    Has anybody had issues with commands not reaching the iTach because of a firewall? I use Zonealarm firewall and have noticed that when I disable the firewall the iTach works fine, and strangely enough, when I enable it the iTach still works. But when I have to restart my computer (which restarts Zonealarm), the iTach no longer receives commands until I disable and leave disabled or enable Zonealarm. I believe Zonealarm starts blocking the commands again at some later time (after a few days) as well without a restart.
    Zonealarm has a log that shows you the communications it has blocked and this usually gives you the opportunity to "allow" the communications by adding their source to a "trusted" zone, but nothing is coming up in the log when I try to send the iTach commands. So not sure what's going on here. If anyone has had similar issues with another firewall, maybe I can apply the same fix here.
    Thanks for any help you can provide.
