I have a GC-100 and on the first port I have a IR blaster I have about 30 some codes working correctly true this blaster. On the second port I have an IR emitter for my TV. In the GC-100 I set up connector 1 as blaster and connector 2 as emitter. If I send an IR signal to my TV true Ilearn it triggers the TV. If I send it true HomeSeer it doesn't. If I change the connector 2 to blaster it works with HomeSeer but there is a red light inside the emitter that always stays on and is kind of annoying. Can anyone tell me why it won't work with HomeSeer when configured as emitter but will work with the Ilearn.
