Have been running a 4-zone whole house system using Xantech 795-20 four zone amplified connecting block and the Nirvis Slink-e since the late 90s. Had to beg for conversion of the Slink-e plug-in in 2005 from HS1 to HS2. The Slink-e zones connect via 3 wires to the screw terminals of the Xantech. Slink-e connects to HS via serial port.
Thinking it might be time to replace the Slink-e, I've been looking at the GC-100-12, to get my 4 zones. In addition, I expect I need purchase 4 GC-GCX cables, one for each zone. First question - does anyone with a GC-100 have it connect to a Xantech amplified block (using the three screw terminals)? If so, does it work well?
Second, how/where do I find the IR codes for use with the GC? Do I need to purchase the learning module too? I'm assuming the IR command setup in HS is the same for Slink-e & GC - correct?
Finally, will the move to HS3 be pretty seamless?
Any thoughts, advice or alternate suggestions greatly appreiated.
Barry
Barry
