I have the ITACH blaster controlling an electric wall fire place. It's just a lighted fireplace with a heater. I have learned the on/off toggle IR and the Intensity UP IR commands. When you turn the unit on, it always comes on at a low setting. You then step up the intensity up to 3 more levels.
Now when I try to do this with the ITACH I setup an event that sends the ON OFF IR, then it sends the Intensity up command 3 times to put the fire place in MAX. However the intensity IR commands don't send. I put a delay of 5 seconds between each IR command and it works. Is this a limitation of the ITACH unit. Do you always need to put a delay of 5 seconds between IR commands?
