Listen to serial port on GC-100 in real-time
    I am able to send commands using the iTach plugin through my GC-100-12 using the command GC.SendSerialData(1,1,"command"), and I can receive data using the command GC.GetSerialData(1,1).
    However, the get-command gives me all the data from the last time I sent that command. If I open a com-port in HS I can set up a script that gives me all incoming data from this port in real-time. Is it possible to set up a script that listens to incoming data one the serial port from the GC device? (preferably on a separate script)
    I need this my using the iTach plugin or other methods without setting the serial-port up as a virtual com-port. I find using virtual com-ports in scripts to be unstable.
    Bump
