Anyone recommend a good it blaster to use? My WF2IR eBay special didn't come with one, I bought the global cache blaster off amazon but it wound up being defective. Could also do an emitter if it has a 12 foot cable.. Thanks in advance!
iR blaster
If a regular emitter will work for you, try one made by Xantech. Have used these with Global Cache GC100 units. If you need the cable longer, either make an extension or use a premade mono audio extension cable. Have no experience with the WF2IR or the IR blaster, but if memory is correct on the GC100, you have to set the unique output via IP for IR blaster or IR emitter output.
