Question about IP2IR operation
    Does the LED blink when sending IR? I can't get this to work, and I don't know if it is actually transmitting IR and I've screwed something up.
    Don
    Don, yes, you should see the transmitter pulsing red.
    How are you transmitting the signal?
      I used the test program found on the GlobalCache site, and the LED's do blink. I'm trying to tie the IP2IR into a Zantech IR block. Will recheck my wiring, but this moving from HS2 to HS3 has me chasing down dozens of issues.
      Thanks for the help.
      Don
        I did a quick check on mine using the codes that I have and for some reason I'm getting "Test Signal Not Successful" when trying it out.
        I even removed the sendir and 1:3 2:1 etc. formerly used to indicate what module you're using (since you're setting it on drop downs now) and still nothing.
        Did you try learning an IR code so you can see what the new format is?
          Not yet. Still trying to bring a bunch of HS2 stuff over.
          Don
