i have 4 wired Globalcache devices on HS3 working without issue. Just purchased a WF2IR and can not get it to appear on the network. Have FIOS wireless set to B/G compatible. The Ihelp utility can not see it, yet I can connect with out a problem via the static IP I set during configuration. It appeared the plugin only connects via the Itach beacon. The Itach has the latest firmware. Any suggestions or thoughts? Any way to enter the static IP in the plugin?
Thanks in advance.
Thanks in advance.
