This package requires version 5.0.0.20 of HomeSeer
    When installing the Beta version of HomeSeer Global Cache IR Controller I get the following error.
    Jul-24 22:43:26 Updater Install/Update of package HomeSeer Global Cache IR Controller failed.
    Jul-24 22:43:26 Updater Error Installation of package HomeSeer Global Cache IR Controller failed. Try disabling the plugin first, then re-try the update.
    Jul-24 22:43:26 Updater Error This package requires version 5.0.0.20 of HomeSeer, and you have version 3.0.0.194 so the installation will not continue.
    Is there a HS V5?
    Greig.
    Scripts =
    Various
    Is there a HS V5?
    Greig.
    Yes, it was released September, 2017
    Joking aside, I noticed the same thing. The install.txt file in the package has
    xxxx,[CHECKVERSION],5.0.0.20
    at the top, where it should have
    xxxx,[CHECKVERSION],3.0.0.0
    HST needs to fix the file, the version of the plug-in was used instead of the minimum version of HS3. Since it failed and left the package in the \zips directory, I just unpacked and installed the files manually.
      Bastards. No free rides in the TARDIS.... AND they're holding out on us.....
      Enabled Plug-Ins:
        "I used V5 and it was really, really good"
        ~ Anonymous Whovian
          Is there a HS V5?
          Greig.
          I noticed you are from Scotland, you should submit a bug report, there is obviously a translation problem between English and whatever you guys speak over there.
          https://forums.homeseer.com/forum/de...plifier-plugin
