Global Cache iTach
    Global Cache iTach
    HS3 .293 GC Plugin version 5.0.0.22
    I am getting this error when I click on "select IR" in GC Settings
    Could not load file or assembly 'Newtonsoft.Json, Version=4.0.8.0, Culture=neutral, PublicKeyToken=30ad4fe6b2a6aeed' or one of its dependencies. The system cannot find the file specified.
    Also I am unable to get the Global Cache Pro version working as well.
    The iTach functions perfect with HS2 using the same PC
    any ideas?
    Thank you
    This isn't really a fix, but I just finished configuring mine with Ultrajones's plugin. Since the trial is free, you might give it a shot. His plugin lets you import IR codes from Global Cache's database. It ended up being less than an evening's work to get my AVR and TV functional and to create a bunch of media events in Homeseer. May be worth a try.
      There is a new version of Global Cache in the Beta section of the Updater, called Global Cache PRO. IF you own the previous version this one is free.
      It allows you to download thousands of Code-Sets. Test Codes, Edit Codes and Learn codes right from the Plugin.
      I've hooked up 5 different iTach IP2IR(s) using the PRO version and it really is a time saver
      Blair
      HomeSeer: HS3 Pro 3.0.0.548
      Hometroller S6 | Devices: 832 | Events: 211
      Plug-Ins: Z-Wave .252 | HSTouch | RFXCOM | UltraRachio3 | Sonos
      BLLAN | BLPLEX | BLLOCK | NetCAM | Global Cache Pro | Blur-Iris4
        It allows you to download thousands rumah of Code-Sets. Test Codes, Edit Codes and Learn codes right from the Plugin.
        thanks for information
