X10 Dim command
  • X10 Dim command
    The X10 dim / bright command to an IR523 does not work. I can see it is received (the LED on the IR523 weakly lights) but never operates. When I use another app (Simple Remote) to do the same thing it has a repeat option time. I use 200ms there and it works. Is this possible with this plugin?
    Solved thanks to post re continuous volume
    "The repeat factor is the first number after the frequency in the IR code set, I changed mine to 50 repeats."
    sendir,1:3,1,38000,1,1,171,171,18,18,18,
    sendir,1:3,1,38000,50,1,171,171,18,18,18,
