Problem using event to trigger channel change
    If I manually go into the plugin and select the device and then the "test" button to select a command (any command) it works fine, but if I make it an event I get the following 'key not present in dictionary' error:
    Feb-01 2:05:36 PM Error Event test ch 5 test ch 5 plugin action failed:The given key was not present in the dictionary.
    Feb-01 2:05:36 PM Event Event Trigger "test ch 5 test ch 5"
    Feb-01 2:05:36 PM Event Event test ch 5 test ch 5 triggered by the event page 'Run' button.
    In your event are you using Control A Homeseer device?
    Look further down the action list and try, Send An IR Command to a device.
    Blair
    HomeSeer: HS3 Pro 3.0.0.548
    Hometroller S6 | Devices: 832 | Events: 211
    Plug-Ins: Z-Wave .252 | HSTouch | RFXCOM | UltraRachio3 | Sonos
    BLLAN | BLPLEX | BLLOCK | NetCAM | Global Cache Pro | Blur-Iris4
      Tried it both ways and it didn't work. Then I deleted each of the IR codesets and started over...that fixed it...I think, I'll test it tonight when I get home, but it's not throwing the error in the log anymore.
