IP2CC on sprinkler system
  • IP2CC on sprinkler system
    For years I have been using an X10 UM506 Universal Module to turn off my sprinkler system. In an attempt to reduce the number x10 devices I am using IP2CC. When the contacts are closed the system should operate. When open system is defeated. The issue is that the contact do not seem to stay closed. The system will operate for a few minutes then stop. If I click ON again, even thought HS is already reporting the contact as ON, the system will start back up. If I turn the contact off with HS the system will stay defeated.
    Not sure how to troubleshoot. ??
    just notice this is an IR forum. I did not see a forum for contact closures.
    Last edited by lpcalcaterra; August 29th, 2018, 08:58 AM. Reason: possible wrong forum.
    Larry
