Manually edit codes feature request
  • Manually edit codes feature request
    Almost all of my devices need a repeat rate changed from 1 to 4 for them to work. This is very tedious to do in the manage IR screen.
    1. Is it possible to edit the configuration files directly?
    2. Can a feature be added that asks for the repeat rate for each new device and automatically updates the codes?
    Homeseer authored the Global Cache PRO plugin, however the IR codes are downloaded from a database at Global Cache .com, which prevents you from grabbing the ir codes directly. HS then stores them away in a database.
    Typically Volume, tuning, channel up/down is all that would need repeat.
    I make my volume control repeat 50 times, and implement the stopir command when you release the button in HS touch, can work just about like a regular remote does
    Blair
    HomeSeer: HS3 Pro 3.0.0.548
    Hometroller S6 | Devices: 832 | Events: 211
    Plug-Ins: Z-Wave .252 | HSTouch | RFXCOM | UltraRachio3 | Sonos
    BLLAN | BLPLEX | BLLOCK | NetCAM | Global Cache Pro | Blur-Iris4
