Device action popup - can you add the unit to the selection too?
  • Device action popup - can you add the unit to the selection too?
    Just installed the plugin - love it, but...
    When I create events, the device popup isn't showing the unit name so I don't know which TV to choose - can it also show the unit name and the device to control?
    Thanks!
    I've programed a lot with the global cache pro and never have used that command. Try this. ..
    Control a homeseer Device
    Select the global cache device to be controlled.
    Then select the command to be sent.
    If your going to program a button for a channel like 1026 try inserting 200 millisecond delay between each digit
    Blair
    HomeSeer: HS3 Pro 3.0.0.548
    Hometroller S6 | Devices: 832 | Events: 211
    Plug-Ins: Z-Wave .252 | HSTouch | RFXCOM | UltraRachio3 | Sonos
    BLLAN | BLPLEX | BLLOCK | NetCAM | Global Cache Pro | Blur-Iris4
      Thanks!
      Well, it turns out that popup is generated from the created device name when you lookup the device online - you can't rename it there and it will be called TV. For example, if you look for manufacturer LG, choose TV - the device created is TV.
      But, that also creates a device in HS - and, I just went to that device in device management and renamed it "TV - Bedroom" and now the popup makes sense! No more string of TV's.
