GC100 Serial ports
  • GC100 Serial ports
    Does anyone know how to begin configuration of the serial ports on a GC100 in HSPro. Also Does anyone have the make on model number of an 1x2 or 1x3 emmitter that works with this unit?
    thanks in advance for your support.
    What OS do you have HS running on? Typically the various GC plugins are not involved with the serial ports, instead, you need to install redirector software on your system that creates a local serial port for the ip address/port for the GC unit. Typically the first serial port is 4999 and the second is 5000. Some plugins can talk directly to the ip address/serial port and don't need a redirector. What are you trying to connect and control on the serial port?
    Cheers
    Al
