continous IR blasting on test
  • continous IR blasting on test
    New user.... so sorry if obvious answer (can't find). I got this working (Pro plugin) with an AV component - seemed ok.
    I created an event to control powerOn, and then tested it..... and I got nonstop IR coming out of the blaster
    I'm sure I probably set up the event wrong. Any suggestions welcome.
    Can you post a screenshot of your event?
      Sadly, I deleted the events to get the IR to stop blurping.
      Just recreated the OFF command as an event and this time it won't work at all. However, if I go into the plugin to test, works fine.
      EDIT: wrong screen shot :-) Let me try that again.
        nevermind.
        i figured it out.
        so much easier than VEra :-)
          i figured it out.
          Great, what was the issue?
            from the THEN statement, i was selecting "control a device". lower on the drop down list was the actual GC "send an IR Signal" choice.
            much easier.
              Screen IR
              Can you paste a Screen shot of what worked?
              Devoir
