Where is this plugin?
  • Where is this plugin?
    It does not appear under Audio / Video and Infra-red (IR) in HS3, am I missing something? (very likely...I'm new!)
    It is in the beta section at the bottom of the list.
    Randy Prade
    Aurora, CO
    Prades.net
      Perfect, thank you. (I was searching every category but that!!)
        I just received an iTach for xmas and was looking as well. I ended up just starting a script that I am using to control the until (by voice and other events passing parameters). I was looking at the plugins and for the limited needs I have, I didn't see the cost viable. Plus HS hasn't seemed to stay up on their plugins (except zwave).
        ' import required modules
        Imports System.Net
        Imports System.Net.Sockets
        Imports System.Text
            Sub Main(ByVal parms as Object)
                Dim strCommand as string
                Dim Yammy_Mute = "sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,21,21,21,21,21,21,64,21,21,21,64,21,64,21,21,21,64,21,64,21,64,21,21,21,64,21,21,21,1517,341,85,21,3655" &vbCR
                Dim Yammy_UnMute = "sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,21,21,21,21,21,21,64,21,21,21,64,21,21,21,21,21,64,21,64,21,64,21,21,21,64,21,21,21,1517,341,85,21,3655" &vbCR
                Dim DTV_Pause = "sendir,1:3,1,38000,1,21,229,45,45,45,22,22,22,22,45,45,22,22,45,22,22,22,22,45,22,1143,114,45,45,45,22,22,22,22,45,45,22,22,45,22,22,22,22,45,22,1143" &vbCR
                Dim Yammy_Power_On = "sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,1517,341,85,21,3655" &vbCR
                Dim Yammy_Power_Off = "sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,1517,341,85,21,3655" &vbCR
                Dim DTV_Power_On = "sendir,1:3,1,39000,1,1,232,46,46,46,23,23,46,23,23,23,23,23,23,23,46,46,46,23,23,1155,116,46,46,46,23,23,46,23,23,23,23,23,23,23,46,46,46,23,23,1155,116,46,46,46,23,23,46,23,23,23,23,23,23,23,46,46,46,23,23,46" &vbCR
                Dim DTV_Power_Off = "sendir,1:3,1,39000,1,1,232,46,46,46,23,23,46,23,23,23,23,23,23,46,46,46,46,46,23,1155,116,46,46,46,23,23,46,23,23,23,23,23,23,46,46,46,46,46,23,1155,116,46,46,46,23,23,46,23,23,23,23,23,23,46,46,46,46,46,23,46" &vbCR
                Dim NEC_Power_On = "sendir,1:2,1,38109,1,1,343,171,22,21,21,21,22,21,22,63,22,63,22,21,22,21,21,21,22,63,22,63,22,63,22,21,22,21,21,64,21,64,21,64,21,21,22,21,22,21,22,63,22,21,21,21,22,21,22,21,21,64,21,64,21,64,21,21,22,63,22,63,22,63,22,63,22,1533,343,85,22,3661,342,85,22,3661,342,85,22,3800" &vbCR
                Dim NEC_Power_Off = "sendir,1:2,1,38000,1,69,342,171,21,21,21,21,21,21,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,21,64,21,64,21,64,21,64,21,64,21,64,21,64,21,64,21,21,21,21,21,1702,342,85,21,3663" &vbCR
                Dim DTV_Digit_9 = "sendir,1:3,1,38000,1,21,229,45,45,45,22,22,22,22,22,22,45,22,22,45,22,45,45,45,22,1143,114,45,45,45,22,22,22,22,22,22,45,22,22,45,22,45,45,45,22,1143" &vbCR
                Dim Yammy_DTV = "sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,64,21,21,21,21,21,64,21,21,21,64,21,21,21,64,21,21,21,64,21,64,21,21,21,64,21,21,21,64,21,21,21,64,21,1517,341,85,21,3655" &vbCR
                Dim Yammy_CD = "sendir,1:1,1,38000,1,69,341,170,21,21,21,64,21,21,21,64,21,64,21,64,21,64,21,21,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,64,21,64,21,21,21,64,21,21,21,64,21,21,21,21,21,21,21,21,21,64,21,21,21,64,21,21,21,64,21,64,21,64,21,1517,341,85,21,3655" &vbCR
                If Instr(parms,"pause") then
                Call IRSend(DTV_Pause)
                hs.setdevicestring(2393, "I have paused the TV", true)
                End If
                If Instr(parms,"mute") then
                Call IRSend(Yammy_Mute)
                hs.setdevicestring(2393, "I have muted the TV", true)
                End If
                If Instr(parms,"unmute") then
                Call IRSend(Yammy_UnMute)
                hs.setdevicestring(2393, "I have unmuted the TV", true)
                End If
                If Instr(parms,"news") then
                Call IRSend(Yammy_Power_On)
                hs.waitsecs(1)
                Call IRSend(Yammy_DTV)
                hs.waitsecs(1)
                Call IRSend(DTV_Power_On)
                hs.waitsecs(1)
                Call IRSend(NEC_Power_On)
                hs.waitsecs(1)
                Call IRSend(DTV_Digit_9)
                hs.setdevicestring(2393, "I have turned on the news", true)
                End If
                If InStr(parms,"television on") orElse InStr(parms,"tv on") then
                hs.setdevicestring(2393, "I have turned the TV On", true)
                    Dim TV_Watts as integer = hs.devicevalue(824)
                    If TV_Watts = 0 then
                        hs.CAPIControlHandler(hs.CAPIGetSingleControl(824,true ,"on",false,true))
                        hs.waitsecs(2)
                    Else
                        'Do Nothing
                    End If
                hs.waitsecs(1)
                hs.waitsecs(1)
                hs.waitsecs(1)
                End If
                If InStr(parms,"television off") orElse InStr(parms,"tv off") then
                hs.setdevicestring(2393, "I have turned the TV Off", true)
                Dim TV_Watts as integer = hs.devicevalueEX(822)
                    If TV_Watts > 50 then
                        Call IRSend(Yammy_Power_Off)
                        hs.waitsecs(1)
                        Call IRSend(DTV_Power_Off)
                        hs.waitsecs(1)
                        Call IRSend(NEC_Power_Off)
                    Else
                        'Do Nothing
                        hs.setdevicestring(2393, "TV is already Off", true)
                    End If
                End If
                If InStr(parms,"russound") then
                    Dim Stereo_Power as integer = hs.devicevalue(833)
                    Dim TV_Power as integer = hs.devicevalue(822)
                    Dim Russound_Zone as integer = hs.devicevalue(1336)
                        If Stereo_Power < 30 then 'Stereo Off
                            hs.waitsecs(1)
                            Call IRSend(Yammy_CD)
                        Else
                            hs.waitsecs(1)
                        End If
                        If Russound_Zone = 0 then
                        End If
                End If
        End Sub
        Sub IRSend(ByVal strCommand as object)
                Dim tcpClient As New System.Net.Sockets.TcpClient()
                tcpClient.Connect("10.0.254.19", "4998")
                Dim networkStream As NetworkStream = tcpClient.GetStream()
                Dim strResponse As String
                strResponse = "No response"
                If networkStream.CanWrite Then
                    Dim sendBytes As [Byte]() = Encoding.ASCII.GetBytes(strCommand)
                    networkStream.Write(sendBytes, 0, sendBytes.Length)
                    Dim bytes(tcpClient.ReceiveBufferSize) As Byte
                    networkStream.Read(bytes, 0, CInt(tcpClient.ReceiveBufferSize))
                    Dim returndata As String = Encoding.ASCII.GetString(bytes)
                    strResponse = "Device responded: " & CStr(returndata)
                Else
                    If Not networkStream.CanWrite Then
                        strResponse = "Error: Cannot write data to the device"
                        tcpClient.Close()
                    End If
                End If
                hs.writelog("iTach Script", strResponse)
                tcpClient.Close()
        End Sub
