Login Authorization Token
  • alexbk66
    Logitech changed their authentication protocol 16 Nov last year. I think latest plugin version has the fix for that as I'm using it - no problems.
  • tonlof
    Same problem for me..
  • mbg0333
    That did not fix my problem.
    Any ideas?
    I use google for my login but previously did not have this problem.
  • mistermike
    Solved
    Ok, here is what I did to get it working on my Hometroller S6 PRO.
    1. Open up your firewall settings
    2. Add another program to the firewall
    3. Select HomeseerHS3
    4. Go to the plugin and rescan devices, rescan activities
    Now to test this out.
  • mistermike
    started a topic Login Authorization Token
    Does anybody have a step by step to get this plugin working properly? I am using version 3.6.5.0. The hub works outside of the plugin. I tried both with and without the login credentials as suggested by another member. This did not work.
    Plugin: Harmony Hub Test Get Active Activity output for:Hub1: LOGITECH WEB SERVICE LOGIN : FAILURE ERROR : harmonyWebServiceLogin : Logitech web service response does not contain a login authorization token -
    Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
