harmonyhubcontrol.exe...
    rien
    in the meanwhile i have now 4 harmony hubs, which work great. however one of them has not a strong wifi signal.
    since i installed this hub, i see sometimes a the harmonyhubcontrol.exe flooding my cpu with abou 25% CPU usage on my I5. which seems not corrected, can you confirm what is causing this and could this be the bad wifi signal for this particular hub? thanks
    Bart
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
    I asked this same question a few months back. Apparently that part of the plugin is created by someone else and it's a known issue that the plugin developer can't fix. I periodically go in and have to kill that process (it will start it back up automatically).
    I plan on trying to "automate" the killing of that process for just that reason.
    MeiAutomtion Home
      You are "unfortunately" correct. Until I can replace this C## program with the official API calls, this is the way to go
      Rien du Pre
      The Netherlands
      Using:
      Homeseer PRO latest HS4 BETA on a Raspberry
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
        Interesting... I just saw this for the first time.. have two hubs.
        Same problem I get occasionally with the Itach plugin as well, ironically. Or if it helps :-)
          Did you figure a way to do this?
            Loads more than once
            I know this is a known problem.... HarmonyHubControl.exe loads itself many times. I go in and kill em most days.
            Jay
              I started to try one of Jon00's plugins, but it didn't work, he suggested another and I just haven't tried it yet
              (sorry I missed this post)
              MeiAutomtion Home
                I had same idea... but it's just one of those problems that's not so bad it's pressing :-)
                Which plugin did Jon suggest?
                  You know what? I think the original one will work fine. I was using Jon00's processs monitor, but found that the process actually was never running (When I was working on it). I had asked him a question because I was also going to use it to track my PLEX server (since I found it had failed one day) and I needed to also know if a process was not running (hence why he suggested another plugin)
                  If you use his process monitor plugin (https://forums.homeseer.com/showthre...00#post1301100), You can see the % of CPU for the process. You can also run an event or script if it reaches a certain %. However, there is no "time" factor for that (25% for more than 10 minutes). Maybe Jon can add that? I think you could accomplish it though with a virtual device and a couple of events. As far as restarting it, you may want to also consider his Application/Process Control which will let you stop the process and/or restart it (https://forums.homeseer.com/showthread.php?t=124787)
                  MeiAutomtion Home
                    Hi Rien,
                    Any idea when you plan to do this?
                    _______________________________________________
                    HS3 : HSpro (3.0.0.460) on Win2012 (vm on ESXi)
                    Plugins: HSTouch, UPBSpud, Kinect, Nest, IFTTT, DirecTV, EasyTrigger, Imperihome, Zwave, RFXcom, UltraMon3, UltraWeatherBug3, UltraGCIR3, UltraLog3, UltraPioneer, PHLocation, Pushover, Pushalot, MCSSPrinklers S, JowiHue
                    Jon00 Plugins: Bluetooth Proximity, Performance Monitor, DB Chart, Links
                      Originally posted by jlrichar View Post
                      Hi Rien,
                      When the official API supports the same functionality as the unofficial. And that's waiting for Logitech, if it will ever come
                      Rien du Pre
                      The Netherlands
                      Using:
                      Plugin's:
                        Oh. OK. I was under the impression you were going to mix official and unofficial to achieve something that neither can alone. For example using the official API to log in, and the unofficial to create homeseer devices from hub activities. This explains why it was taking so long. I might guess that licensing prevents you from doing this.
                          I've had my Harmony Hub Plugin disabled for over 6 months because of this issue. Has there been a change to no longer rly on the process?
                          If not, does anyone have an elegant way to for the process to be killed every X hours? I thought I had done this years ago with another process I needed to routinely kill, but could not figure out how to do it again.
                          John
                          Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
                          Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
                          HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
                          Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
                            Considering the cost of this plugin, I find it unacceptable that I have to babysit it.
                            Just my $29.95
                              Jay
                              I got the same problem. Very annoying. Any chance fixing this?
