The specified executable is not a valid application for this OS platform
  • The specified executable is not a valid application for this OS platform
    I just downloaded the Harmony Hub plugin 3.6.5.0 onto Homeseer HS3 Pro Edition 3.0.0.297 running on Windows XP Professional SP3. I just purchased the Harmony Elite (Software 4.12.36).
    Getting this error:
    Mar-11 4:53:54 PM Harmony Hub Error Plugin: Harmony Hub Get Devices The specified executable is not a valid application for this OS platform.-The specified executable is not a valid application for this OS platform.
    Current Date/Time: 3/12/2017 4:13:12 PM
    HomeSeer Version: HS3 Pro Edition 3.0.0.297
    Operating System: Microsoft Windows XP Professional - Work Station
    System Uptime: 27 Days 22 Hours 22 Minutes 30 Seconds
    IP Address: 192.168.1.12
    Number of Devices: 80
    Number of Events: 51
    Available Threads: 100
    Enabled Plug-Ins
    2.0.89.0: BLRF
    3.6.5.0: Harmony Hub
    3.0.0.68: HSTouch Server
    3.0.0.36: X10
    3.0.1.76: Z-Wave
    Getting this error:
    Enabled Plug-Ins
    2.0.89.0: BLRF
    3.0.0.36: X10
    3.0.1.76: Z-Wave
    hmmm.
    Is this probably Windows XP embedded ?
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      No, it is not Windows Embedded. It is Windows XP Professional SP3. It is running on a VMware Host as a VM
        Attempting to setup PI. I am receiving same error. Sys info:
        HTML Code:
        HomeSeer Version:	HS3 Standard Edition 3.0.0.312 (Windows)
        HomeSeer:	Is Registered
        OS Version:	5.1.2600 Service Pack: 3.0
        Larry
          WinXP SP3
          Can someone confirm is the PI will run on WinXP SP3.
          Larry
            Can you please try this version and let me know the outcome
            https://www.dropbox.com/s/pxsxzig0mg...ntrol.exe?dl=0
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
              Thanks for the response. Running the executable throws error at startup:
              "Failed to start because MSVCP120D.dll was not found"
              Larry
                Copy all these files to your Homeseer \bin\HarmonyHub directory
                https://www.dropbox.com/sh/drted0i5t...W9ZrwRIya?dl=0
                Rien du Pre
                The Netherlands
                Using:
                Plugin's:
