How are activities matched to the Harmony?
    So, I have an issue where for some reason, my receiver doesn't turn off when switching between some activities. To solve this I think I'm going to need to redo some of my activities.
    If I do this and name them the same, can the plugin recognize that and adapt or will I have to adjust my events after I do this?
    I'm just trying to plan this out before I do it.
    MeiAutomtion Home
    Haven't tested it, but I'm pretty sure the activity Id will change. It might work if you change the activity ID in the ini file manually.
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      I will try it. How can I get the Activity ID from the harmony after I change them?
      MeiAutomtion Home
        So I found out the problem with why my activity wasn't working so I don't need to recreate my activities after all.
        MeiAutomtion Home
