Rien - Just installed the plug-in tonight and configured 1 hub. The plug-in connects properly and all the devices show up on the plug-in devices page... but the plug-in does not create a HomeSeer device for the Vizio TV. Do you have any idea why?
Vizio TV Shows Up in Plug-in But No HS Device is Created
Hi Rien - is this what you are looking for?
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony Hub reference/status is : 391--Sony AV Receiver----45125847
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony HubDeviceAssiociate : 388-391
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony Hub Creating Device for Device: Sony AV Receiver
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony Hub reference/status is : 390--Sony DVD----45125903
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony HubDeviceAssiociate : 388-390
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony Hub Creating Device for Device: Sony DVD
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony Hub reference/status is : 389--Roku Streaming Player----45125923
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony HubDeviceAssiociate : 388-389
Jun-06 10:34:01 PM Harmony Hub Plugin: Harmony Hub Creating Device for Device: Roku Streaming Player
Jun-06 10:33:37 PM Harmony Hub Plugin: Harmony Hub reference/status is : 388--PowerOff--Active--1
Jun-06 10:33:37 PM Harmony Hub Plugin: Harmony Hub Creating Device for hub: Harmony Hub
Jun-06 10:32:46 PM Plug-In Finished initializing plug-in Harmony Hub
Jun-06 10:32:46 PM Harmony Hub Plugin: Harmony Hub Running on Windows version
Jun-06 10:32:45 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:17224
Jun-06 10:32:45 PM Plug-In Interface Harmony Hub is running as a trial, 25 days remaining.
Jun-06 10:32:17 PM Info Plugin Harmony Hub with instance: has disconnected
Jun-06 10:32:17 PM Plug-In Shutting down Plug-In: Harmony Hub
Jun-06 10:31:59 PM Harmony Hub Plugin: Harmony Hub reference/status is : 387--PowerOff--Active--1
Jun-06 10:31:59 PM Harmony Hub Plugin: Harmony Hub Creating Device for hub: Harmony Hub
Jun-01 10:35:40 PM Plug-In Finished initializing plug-in Harmony Hub
Jun-01 10:35:40 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:24535
Jun-01 10:35:40 PM Plug-In Interface Harmony Hub is running as a trial, 30 days remaining.
Jun-01 10:35:28 PM Info Plugin Harmony Hub with instance: has disconnected
Jun-01 10:35:28 PM Plug-In Shutting down Plug-In: Harmony Hub
Jun-01 10:20:02 PM Plug-In Finished initializing plug-in Harmony Hub
Jun-01 10:20:02 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:24259
Please reply with the output of the following commands:
Go to the root folder on your system and execute the following commands:
bin\Harmonyhub\HArmonyHubControl list_activities
bin\Harmonyhub\HArmonyHubControl list_devicesRegards,
Rien du Pre
The Netherlands
Using:
Homeseer PRO latest HS4 BETA on a Raspberry
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Originally posted by Rien du Pre View PostPlease reply with the output of the following commands:
Hi,
Can you delete the plugin .ini file en reconfigure the plugin and do a scan and create of the devices, all with debug on please.
Sent me the output of the logging and the plugin.iniRegards,
Rien du Pre
The Netherlands
Using:
Plugin's:
This is the debug log entry for the Vizio TV
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Vudu
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is VIA
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is M-GO
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Media
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputTv
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputRgb
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputHdmi5
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputHdmi4
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputHdmi3
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputHdmi2
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputHdmi1
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputComponent
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is InputAv
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is iHeartRadio
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is ClosedCaption
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Amazon
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Netflix
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is PictureMode
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Wide
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Exit
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Info
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Guide
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Back
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Menu
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Record
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is FastForward
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Pause
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Rewind
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Play
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Stop
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Ok
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is DirectionUp
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is DirectionRight
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is DirectionLeft
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is DirectionDown
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is ChannelUp
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is ChannelDown
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is ChannelPrev
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is VolumeUp
Nov-04 9:38:30 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is VolumeDown
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Mute
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 9
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 8
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 7
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 6
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 5
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 4
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 3
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 2
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 1
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is 0
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is -
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is Enter
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is PowerToggle
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is PowerOn
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get device command output is PowerOff
Nov-04 9:38:29 PM Harmony Hub Plugin: Harmony Hub Test Get Devices commands output for :Hub1 / 45125801: : Vizio TV (ID = 45125801) Vizio - E50-C1 Functions: ---PowerOff ---PowerOn ---PowerToggle ---Enter ---- ---0 ---1 ---2 ---3 ---4 ---5 ---6 ---7 ---8 ---9 ---Mute ---VolumeDown ---VolumeUp ---ChannelPrev ---ChannelDown ---ChannelUp ---DirectionDown ---DirectionLeft ---DirectionRight ---DirectionUp ---Ok ---Stop ---Play ---Rewind ---Pause ---FastForward ---Record ---Menu ---Back ---PictureMode ---Guide ---Info ---Exit ---Wide ---PictureMode ---Netflix ---Amazon ---ClosedCaption ---iHeartRadio ---Input ---InputAv ---InputComponent ---InputHdmi ---InputHdmi1 ---InputHdmi2 ---InputHdmi3 ---InputHdmi4 ---InputHdmi5 ---InputRgb ---InputTv ---Media ---M-GO ---VIA ---Vudu -
ini file
[Settings]
OS version=Windows
Architecture=x86
cb_debug_checked=1
Hub_Polling_Interval=5
[Hub1]
cb_hub1_checked=1
Hub1_Userid=xxxxx
Hub1_Password=xxxxxxxx
Hub1_IP=192.168.0.30
Hub1_Name=Harmony
Hub1_Location=Living Room
Hub1_Floor=First Floor
[Hub2]
cb_hub2_checked=0
[Hub3]
cb_hub3_checked=0
[Hub4]
cb_hub4_checked=0
[Hub5]
cb_hub5_checked=0
[Hub1_Devices]
Hub1_Device1_ID=45125923
Hub1_Device1_Name=Roku Streaming Player
Hub1_Device2_ID=45125801
Hub1_Device2_Name=Vizio TV
Hub1_Device3_ID=45125903
Hub1_Device3_Name=Sony DVD
Hub1_Device4_ID=45125847
Hub1_Device4_Name=Sony AV Receiver
[Hub1_45125923_Commands]
Device Command_1=DirectionDown
Device Command_2=DirectionLeft
Device Command_3=DirectionRight
Device Command_4=DirectionUp
Device Command_5=OK
Device Command_6=Play
Device Command_7=Rewind
Device Command_8=Pause
Device Command_9=FastForward
Device Command_10=Back
Device Command_11=Search
Device Command_12=Info
Device Command_13=Exit
Device Command_14=Home
Device Command_15=InstantReplay
Device Command_16=Options*
[Hub1_45125801_Commands]
Device Command_1=PowerOff
Device Command_2=PowerOn
Device Command_3=PowerToggle
Device Command_4=Enter
Device Command_5=-
Device Command_6=0
Device Command_7=1
Device Command_8=2
Device Command_9=3
Device Command_10=4
Device Command_11=5
Device Command_12=6
Device Command_13=7
Device Command_14=8
Device Command_15=9
Device Command_16=Mute
Device Command_17=VolumeDown
Device Command_18=VolumeUp
Device Command_19=ChannelPrev
Device Command_20=ChannelDown
Device Command_21=ChannelUp
Device Command_22=DirectionDown
Device Command_23=DirectionLeft
Device Command_24=DirectionRight
Device Command_25=DirectionUp
Device Command_26=Ok
Device Command_27=Stop
Device Command_28=Play
Device Command_29=Rewind
Device Command_30=Pause
Device Command_31=FastForward
Device Command_32=Record
Device Command_33=Menu
Device Command_34=Back
Device Command_35=PictureMode
Device Command_36=Guide
Device Command_37=Info
Device Command_38=Exit
Device Command_39=Wide
Device Command_40=PictureMode
Device Command_41=Netflix
Device Command_42=Amazon
Device Command_43=ClosedCaption
Device Command_44=iHeartRadio
Device Command_45=Input
Device Command_46=InputAv
Device Command_47=InputComponent
Device Command_48=InputHdmi
Device Command_49=InputHdmi1
Device Command_50=InputHdmi2
Device Command_51=InputHdmi3
Device Command_52=InputHdmi4
Device Command_53=InputHdmi5
Device Command_54=InputRgb
Device Command_55=InputTv
Device Command_56=Media
Device Command_57=M-GO
Device Command_58=VIA
Device Command_59=Vudu
[Hub1_45125903_Commands]
Device Command_4=0
Device Command_5=1
Device Command_6=2
Device Command_7=3
Device Command_8=4
Device Command_9=5
Device Command_10=6
Device Command_11=7
Device Command_12=8
Device Command_13=9
Device Command_14=Clear
Device Command_15=DirectionDown
Device Command_16=DirectionLeft
Device Command_17=DirectionRight
Device Command_18=DirectionUp
Device Command_19=Select
Device Command_20=Stop
Device Command_21=Play
Device Command_22=Rewind
Device Command_23=Eject
Device Command_24=Pause
Device Command_25=FastForward
Device Command_26=ChapterPrev
Device Command_27=ChapterNext
Device Command_28=Return
Device Command_29=TopMenu
Device Command_30=Menu
Device Command_31=Subtitle
Device Command_32=Audio
Device Command_33=Green
Device Command_34=Red
Device Command_35=Blue
Device Command_36=Yellow
Device Command_37=Display
Device Command_38=Netflix
Device Command_39=Home
Device Command_40=Options
Device Command_41=PopUp
Device Command_42=SEN
Device Command_43=Time
[Hub1_45125847_Commands]
Device Command_5=0
Device Command_6=1
Device Command_7=2
Device Command_8=3
Device Command_9=4
Device Command_10=5
Device Command_11=6
Device Command_12=7
Device Command_13=8
Device Command_14=9
Device Command_15=Mute
Device Command_16=VolumeDown
Device Command_17=VolumeUp
Device Command_18=DirectionDown
Device Command_19=DirectionLeft
Device Command_20=DirectionRight
Device Command_21=DirectionUp
Device Command_22=Select
Device Command_23=Menu
Device Command_24=PresetPrev
Device Command_25=TuneDown
Device Command_26=TuneUp
Device Command_27=PresetNext
Device Command_28=DirectTuning
Device Command_29=Exit
Device Command_30=Display
Device Command_31=AmpMenu
Device Command_32=DmFastForward
Device Command_33=DmPause
Device Command_34=DmPlay
Device Command_35=DmRewind
Device Command_36=DmSkipBack
Device Command_37=DmSkipForward
Device Command_38=DmStop
Device Command_39=InputBd
Device Command_40=InputDmPort
Device Command_41=InputDVD
Device Command_42=InputSaCd/Cd
Device Command_43=InputSat/Catv
Device Command_44=InputTuner
Device Command_45=InputTv
Device Command_46=InputVideo
Device Command_47=Memory
Device Command_48=SoundFieldDown
Device Command_49=SoundFieldUp
[Hub1_Activities]
Hub1_Activity1_ID=-1
Hub1_Activity1_Name=PowerOff
Hub1_Activity2_ID=26643060
Hub1_Activity2_Name=Watch TV
Hub1_Activity3_ID=26643115
Hub1_Activity3_Name=Listen to Music
Hub1_Activity4_ID=26643149
Hub1_Activity4_Name=Watch Netflix
Hub1_Activity5_ID=26643185
Hub1_Activity5_Name=Watch a Movie
Hub1_Active_ActivityID=3
Rien - I just noticed that the Vizio TV commands are now showing up in the event device actions. The plug-in still does not create the actual device though... that's pretty odd. Only 1 activity device is being created also. So.. the devices in my system are still the ones that are shown above in my first post.
Rien - I just added a second Hub to my system and added a second Vizio TV to it. Again, the plug-in does not create a HomeSeer device for the TV. However, I can create an event that will access the TV controls. Do you have any idea why the plug-in won't display the HomeSeer device for either of these TVs?
