Vizio TV Shows Up in Plug-in But No HS Device is Created
  • #16
    Originally posted by Rien du Pre View Post
    I have really no idea, there nothing strange in the name or whatsoever
    I will try and add a Vizio TV to my config and see what happens.
    Odd that both Vizio TVs fail to show up on the device mgmt page. They do show up as Harmony devices in EVENTS though. OK, let me know what you find.
    Learn About HomeSeer
    • #17
      I added a Vizio TV in my setup and it works. See screenshot
      I used a Vizio P55-E1, what type do you have?
      Rien du Pre
      The Netherlands
      Using:
      Homeseer PRO latest HS4 BETA on a Raspberry
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
      • #18
        .... could it be that there's already a device named "Vizio TV"...? (Would love it if the plugin allowed same name for different hubs).
        • #19
          Oh yes, I forgot, If the device already exist (by name) it wil not be created
          I have to dig in my code, because now I remembered I was solving this issue before I became sick.
          Sorry for that.
          But the mystery is solved.
          Keep you posted.
          Rien du Pre
          The Netherlands
          Using:
          Plugin's:
          • #20
            Crossing my fingers for solving it this time around!
            • #21
              OK great. Let me know what to try when you figure it out!
              • #22
                We you able to fix the issue with same name? I have two Apple TV's and had to redo my associations twice! I think it makes sense what you are saying about it not creating duplicate devices. I even tried changing the hub names to no avail. Seems to be issue with actual device name.
                • #23
                  Hi,
                  I'm busy with designing a new version, which will be multi instance, with the ability to have the same names on different instances.
                  It's a big design change, so it takes a a lot of time.
                  Expect a new version this year !!
                  Rien du Pre
                  The Netherlands
                  Using:
                  Plugin's:
