Harmony PI will not load.
  • Harmony PI will not load.
    WARNING: Failed getting InterfaceStatus from Harmony Hub - the interface was not found in the list of active interfaces, the list may need to be refreshed.
    HSInsteon
    Uninstall this Plug-In
    1.0.0.9 N/A Included Disabled
    Insteon
    N/A 3.0.6.0 N/A Licensed (License ID 105371)
    OK
    Sonos
    See plug-in config
    N/A 3.1.0.22 N/A Included
    OK
    Z-Wave
    N/A 3.0.1.130 N/A Included
    OK
    Remote Plug-Ins
    Current Date/Time: 10/16/2017 4:31:54 PM
    HomeSeer Version: HS3 Standard Edition 3.0.0.368
    Linux version: Linux hometrollerSEL 3.16.0-031600-generic #201408031935 SMP Sun Aug 3 23:56:17 UTC 2014 i686 i686 i686 GNU/Linux System Uptime: 0 Days 0 Hours 47 Minutes 28 Seconds
    IP Address: 192.168.1.15
    Number of Devices: 341
    Number of Events: 50
    Available Threads: 199
    Enabled Plug-Ins
    3.6.5.0: Harmony Hub
    3.0.6.0: Insteon
    3.1.0.22: Sonos
    3.0.1.130: Z-Wave
    HELP DESK (copy/paste section below to help desk tickets & emails)
    Current Date/Time: 10/16/2017 4:31:55 PM
    License: Registered
    License: 69302
    User Name and Access Level: default (Admin)
    WAN IP Address: 72.222.215.239
    Web Server Port: 80
    Location: (Latitude) 32.22 (Longitude) 110.97 City/State-US-Arizona,Tucson,110.97,32.22
    Enabled Plug-Ins
    3.0.6.0: Insteon
    3.1.0.22: Sonos
    3.0.1.130: Z-Wave
    Home | Device Status | Device Management | Events | Log | Setup | Global Elements | Control Pa
    Did you try to reinstall the plugin, or are there any errors during the installation of the plugin?
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      I tried several times. I even reset Homeseer
      To factory defaults then re installed PI still get same message on plug in page.
      Any suggestions on how to fix.
        PI harmony will not load
        Oct-16 3:48:25 PM Plug-In Finished initializing plug-in Harmony Hub
        Oct-16 3:48:22 PM Info Plugin Harmony Hub with instance: has disconnected
        Oct-16 3:48:22 PM Error Initializing plug-in(1): Harmony Hub Instance::Error on InitIO: Invalid value: 0
        Oct-16 3:48:22 PM Harmony Hub InitIO called, plug-in is being initialized...
        Oct-16 3:48:22 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:49886
        Oct-16 3:48:01 PM Updater Install/Update of package Harmony Hub was successful.
        Oct-16 3:48:01 PM Updater Copying file: \usr\local\HomeSeer\Docs\HomeSeer HarmonyHub plug-in V3.6 documentation.pdf
        Oct-16 3:48:01 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcr120d.dll
        Oct-16 3:48:01 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcp120d.dll
        Oct-16 3:48:01 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcr110d.dll
        Oct-16 3:48:01 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcp110d.dll
        Oct-16 3:48:01 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\harmonyhubcontrol_linux_a rm.exe
        Oct-16 3:48:01 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\harmonyhubcontrol_linux.e xe
        Oct-16 3:48:01 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\HarmonyHubControl.exe
        Oct-16 3:48:01 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Config\hspi_HarmonyHub.ini
        Oct-16 3:48:01 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\html\Images\HarmonyHub\harmony-hub.jpg
        Oct-16 3:48:01 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\HarmonyHub.AuthorizationToken
        Oct-16 3:48:01 PM Updater Copying file: \usr\local\HomeSeer\HSPI_HarmonyHub.exe
        Oct-16 3:48:00 PM Updater Installing package Harmony Hub
        Oct-16 3:48:00 PM Updater Update HSPI_HARMONYHUB.exe downloaded successfully
        Oct-16 3:47:52 PM Updater Downloading update: Harmony Hub
        Oct-16 3:47:52 PM Updater Starting download of updates
        Oct-16 3:46:41 PM Speaker Speaker host added, Name: hometrollerSEL Instance: Android IP address: 192.168.1.12
        Oct-16 3:46:41 PM HSTouch Server Connecting speaker client to HomeSeer IP 192.168.1.15
        Oct-16 3:46:41 PM HSTouch Server Client Android (192.168.1.12/46557) named Android has CONNECTED.
        Oct-16 3:46:41 PM HSTouch Server Opening connection from:192.168.1.12/46557
          pi harmony not loading
          here is the error report i get when i delete pi on plug in page and try and reinstall..
          Oct-17 2:32:50 PM Z-Wave Device: MAIN THERMOSTAT MASTER Fan State Set to Fan State 1
          Oct-17 2:32:50 PM Z-Wave Device: MAIN THERMOSTAT MASTER Operating State Set to Operating State 2
          Oct-17 2:31:41 PM Updater Install/Update of package Harmony Hub was successful.
          Oct-17 2:31:41 PM Updater Copying file: \usr\local\HomeSeer\Docs\HomeSeer HarmonyHub plug-in V3.6 documentation.pdf
          Oct-17 2:31:41 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcr120d.dll
          Oct-17 2:31:41 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcp120d.dll
          Oct-17 2:31:41 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcr110d.dll
          Oct-17 2:31:41 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcp110d.dll
          Oct-17 2:31:41 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\harmonyhubcontrol_linux_a rm.exe
          Oct-17 2:31:41 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\harmonyhubcontrol_linux.e xe
          Oct-17 2:31:41 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\HarmonyHubControl.exe
          Oct-17 2:31:41 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Config\hspi_HarmonyHub.ini
          Oct-17 2:31:41 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\html\Images\HarmonyHub\harmony-hub.jpg
          Oct-17 2:31:41 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\HarmonyHub.AuthorizationToken
          Oct-17 2:31:41 PM Updater Copying file: \usr\local\HomeSeer\HSPI_HarmonyHub.exe
          Oct-17 2:31:40 PM Updater Installing package Harmony Hub
          Oct-17 2:31:40 PM Updater Update HSPI_HARMONYHUB.exe downloaded successfully
          Oct-17 2:31:32 PM Updater Downloading update: Harmony Hub
          Oct-17 2:31:32 PM Updater Starting download of updates
          Oct-17 2:30:06 PM Plug-In Finished initializing plug-in Harmony Hub
          Oct-17 2:30:03 PM Info Plugin Harmony Hub with instance: has disconnected
          Oct-17 2:30:03 PM Error Initializing plug-in(1): Harmony Hub Instance::Error on InitIO: Invalid value: 0
          Oct-17 2:30:03 PM Harmony Hub InitIO called, plug-in is being initialized...
          Oct-17 2:30:03 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:44239
            The spaces in the log entries in arm and exe don't look good. Is this really as this in the logging?
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
              here is log after trying to reinstall
              Oct-25 11:16:42 PM Plug-In Finished initializing plug-in Harmony Hub
              Oct-25 11:16:39 PM Info Plugin Harmony Hub with instance: has disconnected
              Oct-25 11:16:39 PM Error Initializing plug-in(1): Harmony Hub Instance::Error on InitIO: Invalid value: 0
              Oct-25 11:16:39 PM Harmony Hub InitIO called, plug-in is being initialized...
              Oct-25 11:16:39 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:59064
              Oct-25 11:15:09 PM Plug-In Finished initializing plug-in Harmony Hub
              Oct-25 11:15:06 PM Info Plugin Harmony Hub with instance: has disconnected
              Oct-25 11:15:06 PM Error Initializing plug-in(1): Harmony Hub Instance::Error on InitIO: Invalid value: 0
              Oct-25 11:15:06 PM Harmony Hub InitIO called, plug-in is being initialized...
              Oct-25 11:15:06 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:58669
              Oct-25 11:13:53 PM Plug-In Finished initializing plug-in Harmony Hub
              Oct-25 11:13:53 PM Error Initializing plug-in(2): Harmony Hub Instance::Object reference not set to an instance of an objectSTACK: at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke (System.Runtime.Remoting.Proxies.RealProxy rp, IMessage msg, System.Exception& exc, System.Object[]& out_args) [0x00000] in :0
              Oct-25 11:13:53 PM Info Plugin Harmony Hub with instance: has disconnected
              Oct-25 11:13:53 PM Harmony Hub InitIO called, plug-in is being initialized...
              Oct-25 11:13:53 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:58386
              Oct-25 11:13:29 PM Updater Install/Update of package Harmony Hub was successful.
              Oct-25 11:13:29 PM Updater Copying file: \usr\local\HomeSeer\Docs\HomeSeer HarmonyHub plug-in V3.6 documentation.pdf
              Oct-25 11:13:29 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcr120d.dll
              Oct-25 11:13:29 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcp120d.dll
              Oct-25 11:13:29 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcr110d.dll
              Oct-25 11:13:29 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\bin\HarmonyHub\msvcp110d.dll
              Oct-25 11:13:29 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\harmonyhubcontrol_linux_a rm.exe
              Oct-25 11:13:29 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\harmonyhubcontrol_linux.e xe
              Oct-25 11:13:29 PM Updater Copying file: \usr\local\HomeSeer\bin\HarmonyHub\HarmonyHubControl.exe
              Oct-25 11:13:29 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Config\hspi_HarmonyHub.ini
              Oct-25 11:13:29 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\html\Images\HarmonyHub\harmony-hub.jpg
              Oct-25 11:13:29 PM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\HarmonyHub.AuthorizationToken
              Oct-25 11:13:29 PM Updater Copying file: \usr\local\HomeSeer\HSPI_HarmonyHub.exe
              Oct-25 11:13:29 PM Updater Installing package Harmony Hub
              Oct-25 11:13:29 PM Updater Update HSPI_HARMONYHUB.exe downloaded successfully
              Oct-25 11:13:20 PM Updater Downloading update: Harmony Hub
              Oct-25 11:13:20 PM Updater Starting download of updates
              Oct-25 11:07:14 PM Info Plugin Harmony Hub with instance: has disconnected
              Oct-25 11:07:14 PM Error Initializing plug-in(1): Harmony Hub Instance::Error on InitIO: Invalid value: 0
              Oct-25 11:07:14 PM Harmony Hub InitIO called, plug-in is being initialized...
              Oct-25 11:07:14 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:57244
              Oct-25 11:07:13 PM Plug-In Finished initializing plug-in Harmony Hub
              Oct-25 11:05:13 PM Plug-In Finished initializing plug-in Harmony Hub
              Oct-25 11:05:10 PM Info Plugin Harmony Hub with instance: has disconnected
              Oct-25 11:05:10 PM Error Initializing plug-in(1): Harmony Hub Instance::Error on InitIO: Invalid value: 0
              Oct-25 11:05:10 PM Harmony Hub InitIO called, plug-in is being initialized...
              Oct-25 11:05:10 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:56860
                can you give me a list of the files in \usr\local\HomeSeer\bin\HarmonyHub
                Rien du Pre
                The Netherlands
                Using:
                Plugin's:
                  files
                  i am so sorry to be so dense but where is this file..it appears not to be on my computer
                    In need the list of files in that folder.
                    Go tio that folder using ssh and then ls -all
                    Rien du Pre
                    The Netherlands
                    Using:
                    Plugin's:
                      is this what you need
                      unning comand ls -all
                      total 14448
                      drwxr-xr-x 22 homeseer homeseer 4096 Oct 26 21:47 .
                      drwxr-xr-x 11 root root 4096 Sep 25 2014 ..
                      -rwxr-xr-x 1 homeseer homeseer 77 Aug 28 2013 autostart_hs
                      drwxr-xr-x 7 homeseer root 4096 Oct 15 23:30 bin
                      drwxr-xr-x 4 root root 4096 Feb 9 2015 Bin
                      -rwxr-xr-x 1 homeseer homeseer 271 Sep 20 2013 change_password.sh
                      -rwxr-xr-x 1 homeseer root 7454 Nov 13 2014 check_passwd
                      -rw------- 1 root root 0 Oct 13 2014 Confg
                      drwxr-xr-x 3 homeseer homeseer 4096 Oct 27 22:21 Config
                      drwxr-xr-x 2 homeseer homeseer 4096 Sep 15 22:55 ConfigBackup
                      drwxr-xr-x 3 root root 4096 Nov 10 2015 data
                      drwxr-xr-x 5 homeseer homeseer 4096 Oct 28 22:21 Data
                      drwxr-xr-x 2 root root 4096 Oct 26 21:46 Docs
                      -rwxr-xr-x 1 homeseer homeseer 642 Sep 25 2014 factory.sh
                      -rw-r--r-- 1 root root 70656 Aug 4 2012 FTD2XX_NET.dll
                      -rwxr-xr-x 1 homeseer homeseer 54 Oct 9 2013 go
                      drwxr-xr-x 2 homeseer homeseer 4096 Oct 29 22:59 Grammar
                      -rw-r--r-- 1 root root 17 Nov 28 2016 HarmonyHub.AuthorizationToken
                      -rw-r--r-- 1 homeseer root 76288 Sep 25 08:32 HomeSeerAPI.dll
                      -rw-r--r-- 1 homeseer homeseer 261632 Dec 12 2016 HomeSeerUtil.dll
                      -rw-r--r-- 1 homeseer root 43008 May 20 2016 HSCF.dll
                      -rwxr-xr-x 1 root root 13312 Sep 25 08:32 HSConsole.exe
                      -rw-r--r-- 1 homeseer root 1518 Jul 7 11:14 HSConsole.exe.config
                      -rw-r--r-- 1 root root 357888 Jul 10 19:00 HSPI_BLOnkyo.exe
                      -rw-r--r-- 1 root root 359 May 15 2014 HSPI_BLOnkyo.exe.config
                      -rwxr-xr-x 1 homeseer root 62976 Oct 7 2014 HSPI_CM15A.dll
                      -rw-r--r-- 1 root root 362 Jul 30 2013 HSPI_CURRENTCOST.exe.config
                      -rwxr-xr-x 1 homeseer homeseer 48128 Oct 11 2014 HSPI_HSInsteon.dll
                      -rw-r--r-- 1 root root 50176 Nov 26 2014 HSPI_HSInsteon.exe
                      -rw-r--r-- 1 root root 352 Jan 16 2014 HSPI_HSInsteon.exe.config
                      -rw-r--r-- 1 homeseer homeseer 226304 Aug 5 2015 HSPI_HSTOUCH.dll
                      -rw-r--r-- 1 root root 221184 May 29 2015 HSPI_HSTOUCH.exe
                      -rw-r--r-- 1 root root 90624 Nov 28 2016 HSPI_Insteon.exe
                      -rw-r--r-- 1 root root 357 Nov 7 2014 HSPI_ITUNES.exe.config
                      -rw-r--r-- 1 root root 1249280 Oct 2 16:36 HSPI_Sonos.exe
                      -rw-r--r-- 1 root root 1538 Oct 2 16:36 HSPI_Sonos.exe.config
                      -rwxr-xr-x 1 homeseer homeseer 115712 Oct 13 2014 HSPI_X10.dll
                      -rwxr-xr-x 1 homeseer homeseer 3069440 Dec 12 2016 HSPI_ZWave.dll
                      -rw-r--r-- 1 root root 3152896 Jun 16 12:38 HSPI_ZWave.exe
                      -rw-r--r-- 1 root root 357 Dec 18 2012 HSPI_ZWave.exe.config
                      -rw-r--r-- 1 homeseer homeseer 650752 Dec 12 2016 HSZWLib.dll
                      drwxr-xr-x 15 homeseer homeseer 4096 Oct 15 23:30 html
                      -rwxrwxr-x 1 homeseer homeseer 36 Sep 22 2014 install.sh
                      -rw-r--r-- 1 root root 515072 Nov 28 2016 Insteon.dll
                      -rwxr-xr-x 1 homeseer homeseer 82432 Apr 17 2014 Insteon.Network.dll
                      drwxr-xr-x 2 homeseer homeseer 4096 Oct 26 21:37 Logs
                      -rwxr-xr-x 1 homeseer root 930816 Nov 13 2014 Mail.dll
                      drwxr-xr-x 2 homeseer homeseer 4096 Apr 17 2014 Media
                      drwxr-xr-x 2 homeseer homeseer 4096 Jun 26 2014 mochad
                      -rwxr-xr-x 1 homeseer homeseer 606 Sep 25 2014 password_check.c
                      -rw-rw-r-- 1 homeseer homeseer 22 Sep 22 2014 play_audio.sh
                      -rwxr-xr-x 1 homeseer homeseer 1397 Nov 21 2014 RecoveryInstall.sh
                      -rw-r--r-- 1 root root 24 Nov 25 2014 RecoveryInstall.txt
                      -rwxr-xr-x 1 homeseer root 434 Nov 21 2014 register_with_find.sh
                      -rwxr-xr-x 1 homeseer homeseer 385 Sep 16 2013 restart.sh
                      -rw-r--r-- 1 root root 126976 Dec 10 2012 RssToolkit.dll
                      -rwxr-xr-x 1 homeseer homeseer 14 May 13 2014 run_command_raw.sh
                      -rwxr-xr-x 1 homeseer homeseer 43 Sep 11 2013 run_command.sh
                      -rwxr-xr-x 1 root root 2844672 Sep 25 08:32 Scheduler.dll
                      -rw-r--r-- 1 homeseer homeseer 1529 Jul 27 2013 Scheduler.dll.config
                      drwxr-xr-x 2 homeseer homeseer 4096 Sep 6 23:09 scripts
                      drwxr-xr-x 2 root root 4096 Dec 16 2014 Scripts
                      -rwxr-xr-x 1 homeseer homeseer 405 Sep 16 2013 shutdown_controller.sh
                      -rwxr-xr-x 1 homeseer homeseer 31 Sep 16 2013 shutdown.sh
                        utostart_hs
                        bin
                        Bin
                        change_password.sh
                        check_passwd
                        Confg
                        Config
                        ConfigBackup
                        data
                        Data
                        Docs
                        factory.sh
                        FTD2XX_NET.dll
                        go
                        Grammar
                        HomeSeerAPI.dll
                        HomeSeerUtil.dll
                        HSCF.dll
                        HSConsole.exe
                        HSPI_BLOnkyo.exe
                        HSPI_CM15A.dll
                        HSPI_HSInsteon.dll
                        HSPI_HSInsteon.exe
                        HSPI_HSTOUCH.dll
                        HSPI_HSTOUCH.exe
                        HSPI_Insteon.exe
                        HSPI_Sonos.exe
                        HSPI_X10.dll
                        HSPI_ZWave.dll
                        HSPI_ZWave.exe
                        HSZWLib.dll
                        html
                        install.sh
                        Insteon.dll
                        Insteon.Network.dll
                        Logs
                        Mail.dll
                        Media
                        mochad
                        password_check.c
                        play_audio.sh
                        RecoveryInstall.sh
                        RecoveryInstall.txt
                        restart.sh
                        RssToolkit.dll
                        run_command_raw.sh
                        run_command.sh
                        Scheduler.dll
                        scripts
                        Scripts
                        shutdown.sh
                        speak.sh
                        speak_to_file.sh
                        temp
                        Temp
                        temp.wav
                        update_extra.sh
                        updatehs.sh
                        updater.txt
                        Updates3
                        update.sh
                        usr
                        Wave
                        wave_files
                        ZWaveAES.dll
                        ZWave_Company.dll
                        Home |
                          help
                          are you able to help me????? see threads
                            Go to the folder \usr\local\HomeSeer\bin\HarmonyHub and then ls -all
                            Rien du Pre
                            The Netherlands
                            Using:
                            Plugin's:
                              In Linux/UNIX, the path separator is "/", not "\".
                              So to the OP, once you login via SSH, enter
                              ls -al /usr/local/HomeSeer/bin/HarmonyHub
                              and post results
