Harmony PI will not load.
    #16
    ok i found the files you requested
    now what? thanks for all the help..running comand ls -al /usr/local/HomeSeer/bin/HarmonyHub
    total 6132
    drwxr-xr-x 2 root root 4096 Nov 2 22:01 .
    drwxr-xr-x 7 homeseer root 4096 Oct 15 23:30 ..
    -rw-r--r-- 1 root root 305152 Dec 9 2016 HarmonyHubControl.exe
    -rw-r--r-- 1 root root 408248 Dec 15 2016 harmonyhubcontrol_linux_arm.exe
    -rw-r--r-- 1 root root 383480 Dec 15 2016 harmonyhubcontrol_linux.exe
    -rw-r--r-- 1 root root 821224 Nov 6 2012 msvcp110d.dll
    -rw-r--r-- 1 root root 815192 May 15 2014 msvcp120d.dll
    -rw-r--r-- 1 root root 1697232 Nov 6 2012 msvcr110d.dll
    -rw-r--r-- 1 root root 1824344 May 17 2014 msvcr120d.dll
      #17
      total 6132
      Goto that folder
      cd /usr/local/HomeSeer/bin/HarmonyHub
      And execute 2 commands
      sudo chmod +x harmonyhubcontrol_linux.exe
      sudo chmod +x harmonyhubcontrol_linux_arm.exe
      This should solve you problem.
      Rien du Pre
      The Netherlands
      Using:
      Homeseer PRO latest HS4 BETA on a Raspberry
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
        #18
        It works in my setup
        Wath type of Vizio TV have you configured
        I took a P55-E1
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
          #19
          I don’t know how to execute this command. I am using hs3 pro. I went to system and then to Linux tools. I entered what you gave me but nothing happened.
          Thanks Mark. I am Linux illiterate.
            #20
            The problem is that the executable files (*.exe) don't have the executable attribute set - so they can't run. The chmod +x command (change mode) will add the executable attribute.
            Try this command
            sudo chmod +x /usr/local/HomeSeer/bin/HarmonyHub/*.exe
            Then re-run
            What you want to see change from before is that the 'x' attributes are set for these two .exe files, like so:
            -rwxr-xr-x 1 root root 408248 Dec 15 2016 harmonyhubcontrol_linux_arm.exe
            -rwxr-xr-x 1 root root 383480 Dec 15 2016 harmonyhubcontrol_linux.exe
            (before the highlighted characters were '-' rather than 'x')
            If you can get it to look like this, the files can execute and hopefully things will start working.
