Harmony Hub Error
  • Harmony Hub Error
    Harmony Hub Error Plugin: Harmony Hub Building page Conversion from string "" to type 'Double' is not valid.
    Just setting up the plugin for the first time.
    The username / password / IP are definitely correct.
    Not sure why it's giving this error.
    There are no other errors for this plugin, in the HS3 logfiles.
    And if I go to the plugins devices page it shows 'error' on the screen.
    Thank you for your time.
    Can you sent me some more information, like HS platform, debug logging etc.
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      OK...I started seeing this in my HS3 log every 5 minutes:
      Plugin: Harmony Hub Test Get Active Activity output for:Hub1: LOGITECH WEB SERVICE LOGIN : FAILURE ERROR : harmonyWebServiceLogin : Logitech web service response does not contain a login authorization token -
      Current Date/Time: 10/27/2017 5:58:33 AM
      HomeSeer Version: HS3 Pro Edition 3.0.0.372
      Operating System: Microsoft Windows Server 2016 Datacenter - Server
      System Uptime: 4 Days 21 Hours 41 Minutes 57 Seconds
      IP Address: 10.0.0.70
      Number of Devices: 2028
      Number of Events: 136
      Available Threads: 800
