Harmony Hub version 4.14.112
  • Harmony Hub version 4.14.112
    Does anyone have the plugin working with the harmony hub software version 4.14.112?
    I just purchased my Zee S2 and Harmony hub and this is the software that is on the hub. I can't get the Zee to communicate with the harmony hub.
    Here is what I am seeing.
    Hub 1 devicename: HarmonyHub Location: Theater Hub1 is: Enabled
    Hub 1 Devices:
    No devices found
    Hub 1 Activities:
    No activities found
    I have my userID and password correct but get a access denied response.
    Plugin: Harmony Hub Get Activities ApplicationName='/usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux_arm.exe', CommandLine='mrd10607@yahoo.com xxxxxxxx 10.0.0.11 list_activities_raw', CurrentDirectory='', Native error= Access denied-
    I tried the following (from Bob in the setup thread) but get response "No such file or directory"
    (1) Open up a terminal window (Go to Applications, Utilities, Terminal)
    (2) check your router to see the IP address for HometrollerZee or other Hometroller device
    (3) Type ssh homeseer@192.168.1.114 (or whatever your IP address was from step (2).
    (4) Enter a password. Either "hsthsths3" if you haven't changed it, or your new password.
    (5) Then type "cd \usr\local\HomeSeer\bin\HarmonyHub\" and hit return
    (6) then type "sudo chmod +x harmonyhubcontrol_linux_arm.exe"
    (7) Then go back to your Homeseer Webpage and go to Manage Plug-ins.
    (8) First disable, then re-enable the Harmony plug-in.
    (9) Go to your Harmony plug-in Device page and you should see your activities and devices. Let me know if you get stuck.
    Not sure what I am doing wrong or what to do next.
    I am new to HomeSeer and still learning the software.
    I am using a macbook to do all this if that matters.
    My Zee S2 is controlling my lights just fine. I just can't get connected to the homehub.
    HomeHub software 4.14.112
    Hub 1 Devices:
    No devices found
    Hub 1 Activities:
    No activities found
    Please check in what folder HS3 is installed. Go to that folder and then goto the bin/HarmonyHub folder and execute the chmod command
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Folder location key to setup
      Thanks for the suggestion. I was able to get the hub to be identified by my homeseer controller. I can now control all my devices from my HS3 app.
