Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
  • Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    My hometrollerSEL is not recognizing the devices or events in my Harmony Hub. I went through all the debugging I could, and am now stuck. I am getting this error:
    Any ideas on how to fix this?
    Here is a copy/paste of my log file.
    Dec-21 7:08:48 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    Dec-21 7:08:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Dec-21 7:08:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:08p08
    Dec-21 7:07:48 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    Dec-21 7:07:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Dec-21 7:07:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:07p07
    Dec-21 7:06:48 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    Dec-21 7:06:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Dec-21 7:06:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:06p06
    Dec-21 7:05:49 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    Dec-21 7:05:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Dec-21 7:05:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:05p05
    Dec-21 7:04:49 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    Dec-21 7:04:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Dec-21 7:04:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:04p04
    Dec-21 7:04:09 PM Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
    Dec-21 7:04:09 PM Harmony Hub Plugin: Harmony Hub OS type is 1
    Dec-21 7:04:06 PM Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
    Dec-21 7:03:48 PM Plug-In Finished initializing plug-in Harmony Hub
    Dec-21 7:03:48 PM Harmony Hub Plugin: Harmony Hub Architecture is: i686C
    Dec-21 7:03:48 PM Harmony Hub Plugin: Harmony Hub Test CPU platform: Architecture: i686 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 2 On-line CPU(s) list: 0,1 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 1 Vendor ID: GenuineIntel CPU family: 6 Model: 55 Stepping: 8 CPU MHz: 2600.031 BogoMIPS: 3161.60 Virtualization: VT-x L1d cache: 24K L1i cache: 32K L2 cache: 1024K
    Dec-21 7:03:48 PM Harmony Hub Plugin: Harmony Hub Running on Linux version
    Dec-21 7:03:48 PM Harmony Hub InitIO called, plug-in is being initialized...
    Dec-21 7:03:48 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:45300
    Dec-21 7:03:40 PM Info Plugin Harmony Hub with instance: has disconnected
    Dec-21 7:03:40 PM Plug-In Shutting down Plug-In: Harmony Hub
    Dec-21 7:03:23 PM Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
    Dec-21 7:03:21 PM Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
    Dec-21 7:03:21 PM Harmony Hub Plugin: Harmony Hub OS type is 1
    Dec-21 7:03:19 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    Dec-21 7:03:18 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Dec-21 7:03:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:03p03
    Dec-21 7:02:19 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
    Dec-21 7:02:18 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Can you please try beta version 3.7 download it from https://www.dropbox.com/s/42hk8bqwyu...nyHub.exe?dl=0
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Rein,
      I shut down the plug-in, deleted the old .exe and put the new .exe from the link you provided in the HomeSeer folder in it's place. I see that the menu's are slightly different under the plug-ins tab so it looks like I do have the new version, but I still can not discover devices. Here is what the log looks like now:
      Thanks for the help
      Dec-23 2:38:21 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
      Dec-23 2:38:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 22/17 2:38p0A
      Dec-23 2:37:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 22/17 2:37p09
      Dec-23 2:36:07 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 22/17 2:36p08
      Dec-23 2:35:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 22/17 2:35p07
      Dec-23 2:34:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 22/17 2:34p06
      Dec-23 2:33:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 22/17 2:33p05
      Dec-23 2:32:31 PM Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
      Dec-23 2:32:31 PM Harmony Hub Plugin: Harmony Hub Instance is :
      Dec-23 2:32:31 PM Harmony Hub Plugin: Harmony Hub OS type is 1
      Dec-23 2:32:31 PM Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
      Dec-23 2:32:29 PM Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
      Dec-23 2:32:29 PM Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
      Dec-23 2:32:21 PM Plug-In Finished initializing plug-in Harmony Hub
      Dec-23 2:32:21 PM Harmony Hub Plugin: Harmony Hub Architecture is: i686C
      Dec-23 2:32:21 PM Harmony Hub Plugin: Harmony Hub Test CPU platform: Architecture: i686 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 2 On-line CPU(s) list: 0,1 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 1 Vendor ID: GenuineIntel CPU family: 6 Model: 55 Stepping: 8 CPU MHz: 2599.957 BogoMIPS: 3161.60 Virtualization: VT-x L1d cache: 24K L1i cache: 32K L2 cache: 1024K
      Dec-23 2:32:21 PM Harmony Hub Plugin: Harmony Hub Instance is :
      Dec-23 2:32:21 PM Harmony Hub Plugin: Harmony Hub Running on Linux version
      Dec-23 2:32:21 PM Harmony Hub InitIO called, plug-in is being initialized...
      Dec-23 2:32:21 PM Harmony Hub Plugin: Harmony Hub Instance InitIO is :
      Dec-23 2:32:21 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:40965
      Dec-23 2:32:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 22/17 2:32p04
      Dec-23 2:31:46 PM Updater An item in the Updater is temporarily unavailable: Error getting response stream (ReadDone2): ReceiveFailure Item: http://homeseer.du-pre.com/HS3/FritzBox3/updater.txt
      Dec-23 2:31:32 PM Info Plugin Harmony Hub with instance: has disconnected
      Dec-23 2:31:32 PM Plug-In Shutting down Plug-In: Harmony Hub
        So the Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid. error is gone ?
        But you still do not see the activities and devices?
        Can you delete your HSPI_HarmonyHub.ini file, configure the plugin again, and do the scans again, with debug on.
        Can you than sent met the log output and the HSPI_HarmonyHub.ini file
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
          Hi!
          That's correct - I do not see that error anymore, but still can not discover my devices or events.
          I deleted the .ini file and then re-configured. I could not attach the .ini file since that is not an allowable attachment type.
          Here is what is in the .ini file:
          [Settings]
          OS version=Linux
          Architecture=x86
          cb_debug_checked=1
          Hub_Polling_Interval=70
          [Hub1]
          cb_hub1_checked=1
          Hub1_Userid=slcrc3@gmail.com
          Hub1_Password=HSENC2q+wuva0imMaeBB+YAG8k3w==
          Hub1_IP=192.168.0.33
          Hub1_Name=Living Room TV
          Hub1_Location=Video
          Hub1_Floor=Video
          And here is the log file:
          Dec-24 5:14:27 PM Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
          Dec-24 5:14:27 PM Harmony Hub Plugin: Harmony Hub Instance is :
          Dec-24 5:14:27 PM Harmony Hub Plugin: Harmony Hub OS type is 1
          Dec-24 5:14:27 PM Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
          Dec-24 5:14:25 PM Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
          Dec-24 5:14:25 PM Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
          Dec-24 5:13:30 PM Plug-In Finished initializing plug-in Harmony Hub
          Dec-24 5:13:30 PM Harmony Hub InitIO called, plug-in is being initialized...
          Dec-24 5:13:29 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:45345
          Dec-24 5:13:25 PM Updater An item in the Updater is temporarily unavailable: The request timed out Item: http://automatedhomeonline.com/HomeS...g3_updater.txt
          Dec-24 5:13:06 PM Info Plugin Harmony Hub with instance: has disconnected
          Dec-24 5:13:06 PM Plug-In Shutting down Plug-In: Harmony Hub
