Harmony Hub Error - newby
  • Harmony Hub Error - newby
    Have you read the documentation. Simply create an event to achieve this..
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      yes, I read the documentation but still new so could be making an mistake.
      Did you look at my attached .pdf? I am consistently getting same error.
      Nothing in your documentation addresses how to fix. Can you help?
      I triple checked my passcode.
      use.
      Jan-08 8:56:41 PM
      Harmony Hub Error
      Plugin: Harmony Hub Get Devices ApplicationName='/usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux.exe', CommandLine='jschuller@prodigy.net ********* 10.0.0.70 list_devices_raw', CurrentDirectory='', Native error= Access denied-
        Please read this post for a solution.
        (1) Open up a terminal window (Go to Applications, Utilities, Terminal)
        (2) check your router to see the IP address for HomeSeer system
        (3) Type ssh homeseer@192.168.1.114 (or whatever your IP address was from step (2).
        (4) Enter a password. Either "hsthsths3" if you haven't changed it, or your new password.
        (5) Then type "cd /usr/local/HomeSeer/bin/HarmonyHub/" and hit return
        (6) then type "sudo chmod +x harmonyhubcontrol_linux.exe"
        (7) Then go back to your Homeseer Webpage and go to Manage Plug-ins.
        (8) First disable, then re-enable the Harmony plug-in.
        (9) Go to your Harmony plug-in Device page and you should see your activities and devices.
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
          Thank you!
          Have had trouble with this for months without any clue how to work this out.
            Still having same issues
            Jan-27 4:48:02 AM Harmony Hub Error Plugin: Harmony Hub Get Devices ApplicationName='/usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux_arm.exe', CommandLine='woody.seiders@gmail.com Xxxxxxxxx 192.168.1.201 list_devices_raw', CurrentDirectory='', Native error= Access denied-
              Have followed your directions. Below. I also tried removing the plug in and re-adding.
              Same error. (attached is my log).
              Any other ideas?
              Hub 3.7.0.0
              z-wave 3.0.1.184
              HS3 Pro (SEL) 3.0.0.368
