New version 3.7, available in updater. Existing users please read before upgrading
  • New version 3.7, available in updater. Existing users please read before upgrading
    Version 3.7 is now available.
    Please read the release notes below and existing users please be aware of the bold items !!!
    - Converted the plugin to a multi instance plugin.
    Users of previous version, with more than one hub configured, should add an new instance for their second. third etc.. hub and scan and recreate the devices.
    I know this might cause some inconvenience, but there is no other way to keep things clean.
    - Added support for devices with the same name per plugin instance.
    - Activity device will show status when connection problem with the hub occur
    - Polling cycle can now be set in seconds instead of minutes. Existing users, will have to multiply their polling cycle setting by 60.
    Setting the polling cycle lower than 60 seconds is experimental, it might cause performance issues on both the hub and HomeSeer itself.
    - Code cleanup and minor bug fixing
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
    Rien,
    I started with a clean install and rmoved the ini. And added my hubs.
    However i still encounter this error in the log upon activity device creation;
    jan-13 19:09:10 Error Posting back to plugin web page Harmony Hub:Harmony Hub Keuken: Object reference not set to an instance of an object.-> Server stack trace: Exception rethrown at [0]: at System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
    Same thing happens for all my 4 hubs.
    next to that i have some devices, which dont have commands available in the dropdown list. which seems strange to me.
    Bart
    Regards Bart
    Win7 64Bit on Intel NUCI7 with SSD
    HSPRO 3.
    Devices; 1370 Events; 691
    Jon00 Scripts, JowHue, HSTouch, Plugwise, Z-wave, Ultranetatmo, Ultracam, PHlocation, BLUSBUIRT, MeiHarmony, Buienradar, MEiUnifi Pushover 3P, Random, Nest HSPhone and Blueiris
    Visonic Powermax Alarm System (HS3) Interface: http://www.domoticaforum.eu/viewtopic.php?f=68&t=11129
      Rien,
      I also encounter another issue, i reconfigured all my events but sending a command via an event is not working anymore. I even created new events which also didnt solve it. However just found out that it for the root plugin instance its working, but not for the other instances. No errors in log
      Controlling commands via the devices created ( dropdowns) works as expected.
      Bart
      Verzonden vanaf mijn iPhone met Tapatalk
      Regards Bart
      HSPRO 3.
        I can't seem to get the activity device created for the new requirements to start fresh with >1 hubs.
        Equipment devices and their functions got created and the root device but not the activity device.
        The existing hub (previous version) with the old devices seem to work fine.
        Sent from my ASUS_Z00AD using Tapatalk
        RJ_Make On YouTube
          Originally posted by bartbakels View Post
          Rien,
          Bart
          I have exactly the same issue. Events work o/k with the initial hub 1 instance but not for any further hubs.
            Waiting to update to this version until I know that more than 1 hub is working at a time.
            The older version is running 2 hubs right now...
              How does one "create a new instance"? I saw no plus icon on the Plugin management page...
                It's there for me, maybe you didn't update yet or it failed?
                  Where is "there"?
                    In ‘’manage plugins’’ Page
                      Where is "there"?
                      Right where it should be and where you expected it to be. Here is a picture.
                      The green PLUS to the right of the main or first "Harmony Hub"
                        Thanks, that's where I thought. It didn't show up there for me. Strange!
                        Perhaps a complete reboot of the system is needed.
                        Does multi-hub support work for you?
                          So I wound up deleting the newly added node and all devices associated with it.
                          This time ran both scans, then built out the devices and everything works as expected. I think I make my mistake by running the build activity device before a proper scan had been completed.
                          This created the root device node without any activities, and the root device would not pickup the newly found activities. So that's is definitely a problem.
                          As of this e-mail, everything seems to be working fine with both Hubs.
                          RJ_Make On YouTube
                            Also having the same issues as Bart since upgrading to 3.7
                              I've been looking at this plugin when I upgrade my Harmony. However, if it's now takes three plugins then I'm hosed as long as I'm running on a ZeeS2 with it's 5 plugin limit since I'm at 4 now. Guess I just have to wait till May.
