Hub 2 don't groups devices
  • Hub 2 don't groups devices
    hub 1 was already there when I upgrade to the new version 3.7, then I create a new instance for the hub 2, everything was create but no groups.
    see the picture
    I did erase all the ini files, then recreate the hubs, all fix then, now I need to correct all my events
      This should be fixed now
      Rien du Pre
      The Netherlands
      Using:
      Homeseer PRO latest HS4 BETA on a Raspberry
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
        I am having the same problem with the grouping of my devices. Should I delete the ini files? what is the process?
          If you encounter problems, please delete all devices and ini file first
          Rien du Pre
          The Netherlands
          Using:
          Plugin's:
