Error seeing devices
  • Error seeing devices
    Hello, I am seeing an error when adding devices. I am using a Windows 10 PC and cannot seem to work out what to do to fix it.
    thanks.
    thanks.
    This is odd, it's running the RPi linux version and you are on a Windows PC ???
    Can you add some more logging with debug on?
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Sorry. I should have said I get this error when trying to find devices in the browser of my Hometroller Z2 after having enabled the plugin and filled in the config section for the hub. Does the plugin work with the Hometroller?
        Please try the following:
        cd <your homeseer folder>/bin/HarmonyHub/
        sudo chmod +x harmonyhubcontrol_linux_arm.exe
        and try again.
        Rien du Pre
        The Netherlands
        Using:
        Plugin's:
          I'm just getting no such file or directory one I am logged in.
            Please update to the latest version (3.7.2) and this issue should be solved automatically.
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
