Nothing works since moving to linux
    I have moved to linux and the often flaky hub integration now doesn't work at all. In desperation I deleted all devices and removed the application in full from homeseer. Reinstalled and then tried to add my two hubs and almost literally nothing happens. I have one hub found, no activities and no devices. Doesn't matter how I renoot, restart or click on discover and recreate. I would really like to get this back to at least it's previous state, any ideas. With full debugging on this is this mornings full output from the plugin. In the last two hours I also deleted the authorization token, no difference at all. Both hubs are working perfectly with my phone, my wife's phone and the harmony remote.
    Aug-21 13:47:33 Harmony Hub Plugin: Harmony Hub Active Activity updated
    Aug-21 13:47:33 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 4----Root=0
    Aug-21 13:47:33 Harmony Hub Plugin: Harmony Hub reference/status is : 4--Connection to hub lost or instable--Hub is inActive--0
    Aug-21 13:47:32 Harmony Hub Plugin: Harmony Hub reference/status is : 4--aname--Status--0
    Aug-21 13:47:31 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -6
    Aug-21 13:47:31 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 13:23:26 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 13:17:33 Harmony Hub Plugin: Harmony Hub Active Activity updated
    Aug-21 13:17:33 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 4----Root=0
    Aug-21 13:17:33 Harmony Hub Plugin: Harmony Hub reference/status is : 4--Connection to hub lost or instable--Hub is inActive--0
    Aug-21 13:17:32 Harmony Hub Plugin: Harmony Hub reference/status is : 4--aname--Status--0
    Aug-21 13:17:31 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -5
    Aug-21 13:17:31 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 12:53:26 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 12:47:32 Harmony Hub Plugin: Harmony Hub Active Activity updated
    Aug-21 12:47:32 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 4----Root=0
    Aug-21 12:47:32 Harmony Hub Plugin: Harmony Hub reference/status is : 4--Connection to hub lost or instable--Hub is inActive--0
    Aug-21 12:47:31 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 12:23:26 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 12:17:32 Harmony Hub Plugin: Harmony Hub Active Activity updated
    Aug-21 12:17:32 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 4----Root=0
    Aug-21 12:17:32 Harmony Hub Plugin: Harmony Hub reference/status is : 4--Connection to hub lost or instable--Hub is inActive--0
    Aug-21 12:17:31 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 11:53:26 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 11:47:32 Harmony Hub Plugin: Harmony Hub Active Activity updated
    Aug-21 11:47:32 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 4----Root=0
    Aug-21 11:47:32 Harmony Hub Plugin: Harmony Hub reference/status is : 4--Connection to hub lost or instable--Hub is inActive--0
    Aug-21 11:47:31 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 11:29:32 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 11:29:30 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 11:26:15 Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
    Aug-21 11:26:15 Harmony Hub Plugin: Harmony Hub Instance is :Bedroom
    Aug-21 11:26:15 Harmony Hub Plugin: Harmony Hub OS type is 1
    Aug-21 11:26:15 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is : Bedroom
    Aug-21 11:26:12 Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
    Aug-21 11:26:12 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is : Bedroom
    Aug-21 11:23:26 Starting Plug-In Plugin Harmony Hub started successfully in 173 milliseconds
    Aug-21 11:23:26 Starting Plug-In Initializing plugin Harmony Hub ...
    Aug-21 11:23:26 Info Plugin Harmony Hub with instance Bedroom has connected. IP:127.0.0.1:60450
    Aug-21 11:23:25 Plug-In Finished initializing plug-in Harmony Hub
    Aug-21 11:17:32 Harmony Hub Plugin: Harmony Hub Active Activity updated
    Aug-21 11:17:32 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 4----Root=0
    Aug-21 11:17:32 Harmony Hub Plugin: Harmony Hub reference/status is : 4--Connection to hub lost or instable--Hub is inActive--0
    Aug-21 11:17:31 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 10:51:11 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 10:51:09 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 10:51:05 Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
    Aug-21 10:51:05 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 10:51:02 Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
    Aug-21 10:51:02 Harmony Hub Plugin: Harmony Hub Instance is :
    Aug-21 10:51:02 Harmony Hub Plugin: Harmony Hub OS type is 1
    Aug-21 10:51:02 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 10:48:23 Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
    Aug-21 10:48:23 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 10:48:21 Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
    Aug-21 10:48:21 Harmony Hub Plugin: Harmony Hub Instance is :
    Aug-21 10:48:21 Harmony Hub Plugin: Harmony Hub OS type is 1
    Aug-21 10:48:21 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 10:47:31 Starting Plug-In Plugin Harmony Hub started successfully in 276 milliseconds
    Aug-21 10:47:31 Harmony Hub Plugin: Harmony Hub Set credentials on linux executables
    Aug-21 10:47:31 Harmony Hub Plugin: Harmony Hub Architecture is: x86_6
    Aug-21 10:47:31 Harmony Hub Plugin: Harmony Hub Test CPU platform: Architecture: x86_64 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 4 On-line CPU(s) list: 0-3 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 2 NUMA node(s): 1 Vendor ID: GenuineIntel CPU family: 6 Model: 44 Model name: Intel(R) Xeon(R) CPU E5606 @ 2.13GHz Stepping: 2 CPU MHz: 2132.421 BogoMIPS: 4266.81 Hypervisor vendor: VMware Virtualization type: full L1d cache: 32K L1i cache: 32K L2 cache: 256K L3 cache: 8192K NUMA node0 CPU(s): 0-3 Flags: fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts mmx fxsr sse sse2 ss ht syscall nx rdtscp lm constant_tsc arch_perfmon pebs bts nopl xtopology tsc_reliable nonstop_tsc aperfmperf eagerfpu pni pclmulqdq ssse3 cx16 sse4_1 sse4_2 popcnt aes hypervisor lahf_lm epb kaiser dtherm arat
    Aug-21 10:47:31 Harmony Hub Plugin: Harmony Hub Instance is :
    Aug-21 10:47:31 Harmony Hub Plugin: Harmony Hub Running on Linux version
    Aug-21 10:47:31 Harmony Hub Plugin: Harmony Hub Instance InitIO is :
    Aug-21 10:47:31 Starting Plug-In Initializing plugin Harmony Hub ...
    Aug-21 10:47:30 Info Plugin Harmony Hub has connected. IP:127.0.0.1:58458
    Aug-21 10:47:30 Plug-In Finished initializing plug-in Harmony Hub
    Aug-21 10:47:23 Info Plugin Harmony Hub with instance: has disconnected
    Aug-21 10:47:23 Plug-In Shutting down Plug-In: Harmony Hub
    Aug-21 10:26:15 Harmony Hub Plugin: Harmony Hub Active Activity updated
    Aug-21 10:26:15 Harmony Hub Plugin: Harmony Hub Update Activity reference/status is : 4----Root=0
    Aug-21 10:26:15 Harmony Hub Plugin: Harmony Hub reference/status is : 4--Connection to hub lost or instable--Hub is inActive--0
    Aug-21 10:26:14 Harmony Hub Plugin: Harmony Hub reference/status is : 4--aname--Status--0
    Aug-21 10:26:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -35
    Aug-21 10:26:13 Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
    Aug-21 10:21:11 Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
    Aug-21 10:21:11 Harmony Hub Plugin: Harmony Hub Instance is :
    Aug-21 10:21:11 Harmony Hub Plugin: Harmony Hub OS type is 1
    Aug-21 10:21:11 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 10:21:08 Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
    Aug-21 10:21:08 Harmony Hub Plugin: Harmony Hub WebDevicePage Instance is :
    Aug-21 09:56:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -34
    Aug-21 09:26:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -33
    Aug-21 08:56:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -32
    Aug-21 08:26:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -31
    Aug-21 07:56:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -30
    Aug-21 07:26:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -29
    Aug-21 06:56:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -28
    Aug-21 06:26:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -27
    Aug-21 05:56:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -26
    Aug-21 05:26:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -25
    Aug-21 04:56:13 Harmony Hub Error Plugin: Harmony Hub Test Connectivity:Hub1: -24
    The last response from the developer on this forum seems to be February, is this no longer supported?
      So I guess there's the answer, and a formal complaint about that to Homeseer, who are still selling it, has also been ignored., that's a shame.
