Hi guys. What is the proper way of completely removing this plugin? (Planning on replacing it with SirMeii's). I have two hub instances defined. Do I just uninstall both instances from the plugin management page and then manually deleting the two harmony hub devices? Do I also need to manually delete the .ini file? I remember I tried to uninstalling one of the instances but the Harmony Hub pages for that instance still remains there. (May be the pages will disappear once I uninstall both instances?)
process for uninstalling / removing this plugin
Originally posted by hankli View PostHi guys. What is the proper way of completely removing this plugin? (Planning on replacing it with SirMeii's). I have two hub instances defined. Do I just uninstall both instances from the plugin management page and then manually deleting the two harmony hub devices? Do I also need to manually delete the .ini file? I remember I tried to uninstalling one of the instances but the Harmony Hub pages for that instance still remains there. (May be the pages will disappear once I uninstall both instances?)
I just re-installed this plugin (so I could document these steps for you) so this is what you should need to do:
Stop the plugin and all instances
Delete the plugin and all instances from the plugin management screen (This should delete the main EXE for the plugin)
Delete any HS devices for it
Then, on your HS machine, Delete these files/folders
/Bin/HarmonyHub/ <!--- whole folder
/Config/hspi_HarmonyHub.ini
/Config/hspi_HarmonyHub.ini.bak
/HTML/images/HarmonyHub/ <--- whole folder
Also check the /Logs/ folder in case you have any logs. I did not, but I only installed, started then immediately stopped the plugin.
I also had a file in /Docs/ called HomeSeer HarmonyHub plug-in V3.7 documentation.pdf, which you might want to remove (Though it is only a pdf).
let me know if this isn't clear.
@HomeSeer Staff, there should be a way for a developer to write an uninstall script or to read the install file and delete what was added. I have to go through after a test a plugin and remove any extra stuff that was added.
- 1 like
