IR signal works via Activity but not via Device
    I am trying to find out why sending the "AC on" device command doesn't work via as event but works fine if I run the activity from the Device List page in HS3.
    The setting in my remote is to execute the signal via IR2 port (which all works fine from the Harmony application and from the remote itself)
    Any possible causes?
    i don't have a simple answer, can please check if it has something to do with the IR port, by configuring it in the hub for both ports. Is IR 2 transmitting any IR signals when the activity is running?
    Regards,
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
      Yes. I will try tonight.
      Sent from my Nexus 5 using Tapatalk
        I tried again (and just remembered that already tried before) it doesn't work either way
        just as an activity
