Harmony plugin for Linux?
  • #46
    Try setting the permissions how you want them before creating the zip file. Right now, your zip file contains this:
    -rw-r--r-- 1 pi pi 17 Nov 28 2016 HarmonyHub.AuthorizationToken
    -rw-r--r-- 1 pi pi 305152 Dec 9 2016 HarmonyHubControl.exe
    -rw-r--r-- 1 pi pi 408248 Dec 15 2016 harmonyhubcontrol_linux_arm.exe
    -rw-r--r-- 1 pi pi 383480 Dec 15 2016 harmonyhubcontrol_linux.exe
    -rw-r--r-- 1 pi pi 1048004 Dec 3 11:13 HomeSeer HarmonyHub plug-in V3.7 documentation.pdf
    -rw-r--r-- 1 pi pi 940613 Jan 12 22:14 HomeSeer HarmonyHub plug.pdf
    -rw-r--r-- 1 pi pi 190464 Jan 12 16:22 HSPI_HarmonyHub.exe
    -rw-r--r-- 1 pi pi 85 Dec 3 10:32 hspi_HarmonyHub.ini
    -rw-r--r-- 1 pi pi 512 Dec 3 10:32 install.txt
    -rw-r--r-- 1 pi pi 821224 Nov 6 2012 msvcp110d.dll
    -rw-r--r-- 1 pi pi 815192 May 15 2014 msvcp120d.dll
    -rw-r--r-- 1 pi pi 1697232 Nov 6 2012 msvcr110d.dll
    -rw-r--r-- 1 pi pi 1824344 May 17 2014 msvcr120d.dll
    The 'x' bit isn't set on anything. Execute 'chmod +x *.exe *.dll' before you zip it up.
    • #47
      Doesn't work :-(
      Rien du Pre
      The Netherlands
      Using:
      Homeseer PRO latest HS4 BETA on a Raspberry
      Plugin's:
      RFXCOM, mcsMQTT, Z-Wave
      • #48
        I think this method should work for you -
        Include a file "chmod.sh" in your installer:
        #/bin/sh
        chmod +x $(dirname $0)/*.exe
        Install it in your bin directory (.\bin\HarmonyHub)
        Run this during your plugin initialization, calling it as follows
        /bin/sh <hs3_root><hs3_root>/bin/HarmonyHub/chmod.sh
        Calling a script this way allows it to run even though its 'x' permission bits aren't set.</hs3_root></hs3_root>
        • #49
          #/bin/sh
          Good idea !!!!
          Don't need to use sudo in the script?
          Rien du Pre
          The Netherlands
          Using:
          Plugin's:
          • #50
            Originally posted by Rien du Pre View Post
            Good idea !!!!
            Thanks to the suggestion of Zwolfpack, this issue has been resolved. Credentials are now automatically set.
            This was a long term problem and finally solved :-)
            Rien du Pre
            The Netherlands
            Using:
            Plugin's:
