Harmony Hub plugin Information
This topic is closed.
This is a sticky topic.
  • Harmony Hub plugin Information
    This plug-in is designed to allow HomeSeer 3 to interface with Logitech Harmony Hub series of devices.
    For more information goto here
    This plugin supports HS3 Windows and Linux systems(for Linux, please contact me)
    Version 3.0.0.0 Initial release.
    Version 3.1.0.0 Minor bug fixes.
    Version 3.1.5.0 Minor bug fixes.
    Version 3.2 (April 2015)
    - Added support for in total 5 Hub’s (was 3)
    - Simplification of the used devices. Now I only use 1 HS device per Hub, with a dropdown list of the activities.
    - Device value support to check for the current activity based on a value.
    - Minor bug fixes
    Version 3.3 (January 2016)
    - Ability to rename the hub name
    - HS devices for hub devices with control buttons or dropdown list
    - Minor bug fixes
    Version 3.4 (February 2016)
    - Linux support
    - Support for 50+ device commands
    - Minor bug fixes
    Version 3.6
    - Raspberry PI support
    - Bug fixes
    Version 3.7
    - Converted the plugin to a multi instance plugin.
    Users of previous version, with more than one hub configured, should add an new instance for their second. third etc.. hub and scan and recreate the devices.
    I know this might cause some inconvenience, but there is no other way to keep things clean.
    - Added support for devices with the same name per plugin instance.
    - Activity device will show status when connection problem with the hub occur
    - Polling cycle can now be set in seconds instead of minutes. Existing users, will have to multiply their polling cycle setting by 60.
    Setting the polling cycle lower than 60 seconds is experimental, it might cause performance issues on both the hub and HomeSeer itself.
    - Code cleanup and minor bug fixing
    Rien du Pre
    The Netherlands
    Using:
    Homeseer PRO latest HS4 BETA on a Raspberry
    Plugin's:
    RFXCOM, mcsMQTT, Z-Wave
