I've set it up. But for some reason i cannot access it from HS. It says it hasn't found any devices. and I'm very sure that the login is correct.
I get this error though:
But I'm sure the login is correct. I just tested the login with myharmony app.
jul-19 09:59:01 Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: LOGITECH WEB SERVICE LOGIN : FAILURE ERROR : harmonyWebServiceLogin : Logitech web service response does not contain a login authorization token -
