I am thinking of getting the Hub sys. How does it connect with HS3? WIFI, IR or a hardwire? Can you trigger anything in HS? Do you need to create a custom event on the remote to trigger HS actions?
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
